| | WMI Exception - System.Runtime.InteropServices.COMException I have a Windows service written in C# that is configured to automatically start. Sometimes - maybe 20% of the time - the service fails to start due to an exception in WMI code. I haven't made my service dependent on WMI (or any other service) because it appears that .net WMI calls automatically start the WMI service if necessary. Below are the details. What causes this? How can I make this code work 100% of the time? The code is trying to translate a well-known group SID to its name like "Administrators". I was thinking about wrapping my code in try catch and if it fails, waiting 5 seconds and trying again, but this is guesswork. I also might make the service dependent on winmgmt. Here's the exception: Service cannot be started. System.Runtime.InteropServices.COMException (0x80010002) Call was canceled by the message filter. (Exception from HRESULT: 0x80010002 (RPC_E_CALL_CANCELED)) at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo) at System.Management.ManagementScope.InitializeGuts(Object o) at System.Management.ManagementScope.Initialize() at System.Management.ManagementObjectSearcher.Initialize() at System.Management.ManagementObjectSearcher.Get() at Magaram.TimeLimits.Server.AccountManager.GetGroupNameFromSid(SecurityIdentifier sid) at Magaram.TimeLimits.Server.AccountManager..ctor() at Magaram.TimeLimits.Server.TimeLimitService.CreateRealService(SessionManager sessionManager) at Magaram.TimeLimits.ServerHost.TimeLimitsWindowsService.OnStart(String[] args) at System.ServiceProcess.ServiceBase.ServiceQueuedMainCallback(Object state) My code: internal static string GetGroupNameFromSid(SecurityIdentifier sid) { SelectQuery query = new SelectQuery("Win32_Group", string.Format("Domain='{0}'", Environment.MachineName)); using (ManagementObjectSearcher searcher = new ManagementObjectSearcher(query)) { foreach (ManagementObject group in searcher.Get()) { string sddl = group["SID"] as string; if (sddl.ToLower().Trim() == sid.Value.ToLower().Trim()) { string groupName = (string)(group["Name"]); return group["Name"] as string; } } } throw new ArgumentOutOfRangeException("sid", string.Format("Could not get the group name for sid: {0}", sid.Value)); } |
| | Found any solution Hi, I am having the same kind of problem, while using ManagementEven****cher class in system.management namespace. I need to know that if find any solution/reason for the problem you are having. Thanks Hassan jmagara wrote: WMI Exception - System.Runtime.InteropServices.COMException 22-Sep-08 I have a Windows service written in C# that is configured to automatically start. Sometimes - maybe 20% of the time - the service fails to start due to an exception in WMI code. I haven't made my service dependent on WMI (or any other service) because it appears that .net WMI calls automatically start the WMI service if necessary. Below are the details. What causes this? How can I make this code work 100% of the time? The code is trying to translate a well-known group SID to its name like "Administrators". I was thinking about wrapping my code in try catch and if it fails, waiting 5 seconds and trying again, but this is guesswork. I also might make the service dependent on winmgmt. Here's the exception: Service cannot be started. System.Runtime.InteropServices.COMException (0x80010002) Call was canceled by the message filter. (Exception from HRESULT: 0x80010002 (RPC_E_CALL_CANCELED)) at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo) at System.Management.ManagementScope.InitializeGuts(Object o) at System.Management.ManagementScope.Initialize() at System.Management.ManagementObjectSearcher.Initialize() at System.Management.ManagementObjectSearcher.Get() at Magaram.TimeLimits.Server.AccountManager.GetGroupNameFromSid(SecurityIdentifier sid) at Magaram.TimeLimits.Server.AccountManager..ctor() at Magaram.TimeLimits.Server.TimeLimitService.CreateRealService(SessionManager sessionManager) at Magaram.TimeLimits.ServerHost.TimeLimitsWindowsService.OnStart(String[] args) at System.ServiceProcess.ServiceBase.ServiceQueuedMainCallback(Object state) My code: internal static string GetGroupNameFromSid(SecurityIdentifier sid) { SelectQuery query = new SelectQuery("Win32_Group", string.Format("Domain='{0}'", Environment.MachineName)); using (ManagementObjectSearcher searcher = new ManagementObjectSearcher(query)) { foreach (ManagementObject group in searcher.Get()) { string sddl = group["SID"] as string; if (sddl.ToLower().Trim() == sid.Value.ToLower().Trim()) { string groupName = (string)(group["Name"]); return group["Name"] as string; } } } throw new ArgumentOutOfRangeException("sid", string.Format("Could not get the group name for sid: {0}", sid.Value)); } EggHeadCafe - Software Developer Portal of Choice WPF DataGrid Custom Paging and Sorting http://www.eggheadcafe.com/tutorials...tom-pagin.aspx |
| Object cast exception at runtime | .NET General | |||
| System Service Exception | Vista General | |||
