| | find text in document does not work Please advise: Find text in Document works sometimes and not others when doing a searh in a 75 page document. If I search for the name Larry, it may bring up 3 names then it freezes. If I search for the name Laura, it may not work at all but will work If I limit the search to lau -- and of course this is not helpful to me, PLEASE HELP.... Thank you |
| | Re: find text in document does not work "J" <J@xxxxxx> wrote in message news:9CC46DF3-EA9C-4EC2-92BE-5ADE27F7C041@xxxxxx Quote: > Please advise: > Find text in Document works sometimes and not others when doing a searh in > a > 75 page document. > If I search for the name Larry, it may bring up 3 names then it freezes. > If I search for the name Laura, it may not work at all but will work If I > limit the search to lau -- and of course this is not helpful to me, > PLEASE > HELP.... > > Thank you > > you using a different application? You've posted your question in a .NET programming group, so telling us what software is causing you problems will help get you information on appropriate groups for you. |
| Create a new text document in folder | Vista General | |||
| Looping Through A Text File To Find Patterns From Another Text Fil | PowerShell | |||
| scanning text document | Vista print fax & scan | |||
| Find function does not find messages containing text. | Vista mail | |||
| Simple text document problem? | Vista General | |||
