| | Print Spooler takes large % of CPU I have a recurring issue with a Print Spooler on a Windows 2000 Server. A print job will get stuck and take a large amount of the CPU time. I stop the print spooler in Services, go into Windows (or Winnt) | System32 | Spool | Printers and delete all jobs in that folder and restart the print spooler. This fixes the issue temporarily, but several days later, the same process occurs. Is there a way to trace where the stuck print job is coming from, or has anyone run into this same issue? Thanks, David |
| | Re: Print Spooler takes large % of CPU "davidtheweb" <davidtheweb@xxxxxx> wrote in message news:FA76F3BC-4CAA-48C4-9E9B-510B5429875F@xxxxxx Quote: >I have a recurring issue with a Print Spooler on a Windows 2000 Server. A > print job will get stuck and take a large amount of the CPU time. > > I stop the print spooler in Services, go into Windows (or Winnt) | > System32 > | Spool | Printers and delete all jobs in that folder and restart the > spooler. This fixes the issue temporarily, but several days later, the > same > process occurs. > > Is there a way to trace where the stuck print job is coming from, or has > anyone run into this same issue? > that indicate Windows 2k. The is a .Net programmer's NG you are posting to at this time. |
| Vista Machine Takes Over Print - XP Printers Can't Print Afterwards | Vista networking & sharing | |||
| HOw do I start the print spooler so I can install my print drivers? | Vista installation & setup | |||
| Print Spooler hangs and doesn't print | Vista print fax & scan | |||
| Print Spooler Locks up After first Print | Vista hardware & devices | |||
| Vista takes forever to delete large blocks of files | Vista General | |||
