Vista - System restore
Old 09-25-2008   #1 (permalink)
oreges
System restore
I have lost thesystem restore function completely, when i open control panel
then the system folder it is not there.
The whole application seems not to be there.
I am using XP professional SP3
Old 09-25-2008   #2 (permalink)
XP Pro 32bit
Re: System restore
Did you try right clicking on My Computer then clicking on properties?
Old 09-25-2008   #3 (permalink)
Vista Ultimate x64 Bill Gates Signature Edition #3520
Re: System restore
1. Ensure you aren't in a non-administrator account
2. Has your PC been infected with a virus / spyware in the past or present?
3. How many user accounts are there on this PC ?
4. Is this problem in all user accounts?
If there is only one account, then make a new one (call it anything you want). I do not mean enabling the guest account.
If after loading that account the problem is not present, then an account modification from viruses/spyware/personal hacking/not-so-great utility program may be the culprit.
System Restore Task - Change Automatic Restore Point Schedule Tutorials
System Restore error (create restore point), event ID: 8193 Vista General
System Restore: do restore points persist after a restore? Vista General
System restore hasn't held a restore point since I installed Vista Vista General
system restore not creating system restore everyday Vista General
