Vista - Parameter Problem in OleDB
Old 09-29-2008   #1 (permalink)
Benedictum
I have the following code that derives the value from a query string -
// the code ->
protected void Page_Load(object sender, EventArgs e)
string theTime = Request.QueryString["time"];
string altitude = Request.QueryString["altitude"];
string latitude = Request.QueryString["latitude"];
string longitude = Request.QueryString["longitude"];
lblTtime.Text = theTime;
lblAltitude.Text = altitude;
lblLatitude.Text = latitude;
lblLongitude.Text = longitude;
if (theTime == "" || altitude == "" || latitude == "" || longitude == "")
// do nothing
else
string conn =
ConfigurationManager.AppSettings["ConnectionString"].ToString();
// lblConn.Text = conn;
string selectSQL = "update gps_table set ";
selectSQL += "gps_time= @gps_time,";
selectSQL +="gps_altitude = @gps_altitude,";
selectSQL +="gps_latitude = @gps_latitude,";
selectSQL +="gps_longitude = @gps_longitude where gps_id=1";
OleDbConnection MyConnection = new OleDbConnection(conn);
OleDbCommand MyCommand = new OleDbCommand(selectSQL, MyConnection);
MyCommand.Parameters.Add(new OleDbParameter("@gps_time",
Convert.ToDateTime(theTime)));
MyCommand.Parameters.Add(new OleDbParameter("@gps_altitude",
Convert.ToDouble(altitude)));
MyCommand.Parameters.Add(new OleDbParameter("@gps_latitude", latitude));
MyCommand.Parameters.Add(new OleDbParameter("@gps_longitude", longitude));
MyConnection.Open();
MyCommand.ExecuteNonQuery();
I am getting the exception : Parameter @gps_latitude has no default value.
Why? How I can I solve this problem? Is this a VS2005 bug?
Old 10-05-2008   #2 (permalink)
Mr. Arnold
Re: Parameter Problem in OleDB
"Benedictum" <Benedictus@xxxxxx> wrote in message
news:eluzu3pIJHA.3644@xxxxxx
> // the code ->
> // do nothing
> else
> string conn =
No, it's not a bug. I don't use OleDb. I use SQL Command Objects myself,
which would be using a T-SQL Update statement. However, it must be that
ADO.Net and Oledb are looking at the Parm.Add for "@gps_latitude", latitude
and latitude is null or something and maybe another "," needs to be in the
statement to indicate what default value should be given if latitude is null
data.
You can approach it at that angle. You should find out what is in latitude
and find out how to give a default value if Oledb determines that it needs a
default value applied to make the statement successful.
Old 10-05-2008   #3 (permalink)
Jack Jackson
OLEDb uses positional parameters marked by ?, not @.
See
<http://msdn.microsoft.com/en-us/library/system.data.oledb.oledbparameter.aspx>
On Mon, 29 Sep 2008 20:43:24 -0500, "Benedictum"
<Benedictus@xxxxxx> wrote:
>// the code ->
>// do nothing
>else
>string conn =
Null parameter problem .NET General
Script parameter problem PowerShell
Using multiple Parameter sets for a Parameter PowerShell
How to best control parameter attributes and parameter parsing in your own scripts? PowerShell
Problem with parameter passing? PowerShell
