| | Project build and publish error I have two projects which I try to publish together. I cannot publish the projects with one-click together because the 2nd project failed to build. However, the project builds and publishes on its own. I have one-click just set on the first project. All application files are set to include and there are no warning signs. Any ideas? The projects are fully trusted. I'm also using SVN where all files are green. Segue |
| [Project] My HAF 932 Water-Cooling Build *56K Warning* | Overclocking & Cooling | |||
| Installing MS Project error | Vista General | |||
| Windows Movie Maker Publish error | Vista music pictures video | |||
| Build Events question on project name and path | .NET General | |||
| In any project, Can't we refer classes directly, (without addingphysically in the project)? | .NET General | |||
