Vista - Difference between Show and ShowDialog?
Old 10-06-2008   #1 (permalink)
Curious
I have a windows form, and it seems that I can use either Show or
ShowDialog to get it displayed. I wish to know the difference between
the two methods. Thanks!
Old 10-06-2008   #2 (permalink)
EricW
Re: Difference between Show and ShowDialog?
if you show your form with show, it will put it on the screen and then
program will continue on the next line as for showdialog will put it on the
screen and wait for a close command.
It's the difference between a modal and modeless form.
2 second google gave me:
http://msdn.microsoft.com/en-us/libr...dh(VS.80).aspx
gr,
Eric
"Curious" <fir5tsight@xxxxxx> schreef in bericht
news:d7a76bae-ca78-42d7-b530-a641a6a2d48c@xxxxxx
Old 10-06-2008   #3 (permalink)
Curious
Hi Eric,
Thanks! This info is useful.
I can't believe the difference Vista General
show desktop doesn't show gadgets Vista General
Windows Forms without ShowDialog? PowerShell
difference between 64 bit and 32 bit os Vista General
ShowDialog vs. Application.Run PowerShell
