| | Need a technique to speed up processing I had written a vb.net app for clients that wanted to use a datagrid like a spreadsheet. Rather than edit one line at a time, they wanted all lines available at all times. That seemed to work fine, except now there is a response-time issue when there are many lines in the grid. The viewstate is getting very large. There are close to 50 input fields on each row, and some folks are adding upwards of 50 rows or more. The real issue is that as values are entered in a few specific columns, I need the app to jump back over to the server, validate the input, and possibly pre-fill a few other values in that row. As the grid gets larger, changing a value and making a round trip to the server can take 15-20 seconds. And validation must take place on the server, because I have to hit the database. I would have preferred to bury the validation tables in the screen, but they're way too large. I'm using Anthem keep from having to refresh the entire screen all the time, and that helps keep the screen from jumping around. But what I really need is a way to send to the server only a few fields rather than the entire viewstate. It has to be flexible, though. When I'm validating those specific fields, I want only those fields sent to the server. But if they click the Save button, all of it needs to go. I've made some tests using Anthem.InvokePageMethod and Anthem.InvokeControlMethod, but they still run slow. They seem to call the routine I want, but that's after the entire viewstate is sent in. I've tried EnableCallBack on Anthem fields, but it seems like that's something that needs to be defined before the screen is painted. Since I don't know if they're going to enter a value or click Save, I don't know which fields to set up for EnableCallBack. If I do that for the entire grid, they all get returned, and I haven't gained anything. I've considered setting up another class to receive a message, but that would have to open another window, wouldn't it? What I really want is a way to send a few fields to the server, which in response, will set a few other fields within the grid. Seems to me that there must be a way to do that, but after two days of searching, I've yet to find it. I need a clue. Thanks for any suggestions. Dan |
| | Re: Need a technique to speed up processing What about calling a web service from the aspx page, the client script would be responsible for populating any fields etc, but it would mean you're not posting back all the time. You can also lessen the amount of data being sent to the page by storing the viewstate in your DB. "dang57" <dan.greitzer@xxxxxx> wrote in message news:d58227f1-ec20-47b0-b250-c3e08ee06443@xxxxxx Quote: >I had written a vb.net app for clients that wanted to use a datagrid > like a spreadsheet. Rather than edit one line at a time, they wanted > all lines available at all times. That seemed to work fine, except > now there is a response-time issue when there are many lines in the > grid. The viewstate is getting very large. > > There are close to 50 input fields on each row, and some folks are > adding upwards of 50 rows or more. The real issue is that as values > are entered in a few specific columns, I need the app to jump back > over to the server, validate the input, and possibly pre-fill a few > other values in that row. As the grid gets larger, changing a value > and making a round trip to the server can take 15-20 seconds. And > validation must take place on the server, because I have to hit the > database. I would have preferred to bury the validation tables in the > screen, but they're way too large. > > I'm using Anthem keep from having to refresh the entire screen all the > time, and that helps keep the screen from jumping around. But what I > really need is a way to send to the server only a few fields rather > than the entire viewstate. It has to be flexible, though. When I'm > validating those specific fields, I want only those fields sent to the > server. But if they click the Save button, all of it needs to go. > > I've made some tests using Anthem.InvokePageMethod and > Anthem.InvokeControlMethod, but they still run slow. They seem to > call the routine I want, but that's after the entire viewstate is sent > in. I've tried EnableCallBack on Anthem fields, but it seems like > that's something that needs to be defined before the screen is > painted. Since I don't know if they're going to enter a value or > click Save, I don't know which fields to set up for EnableCallBack. > If I do that for the entire grid, they all get returned, and I haven't > gained anything. > > I've considered setting up another class to receive a message, but > that would have to open another window, wouldn't it? > > What I really want is a way to send a few fields to the server, which > in response, will set a few other fields within the grid. Seems to me > that there must be a way to do that, but after two days of searching, > I've yet to find it. I need a clue. > > Thanks for any suggestions. > Dan |
| | Re: Need a technique to speed up processing Thanks for the suggestion, Adrain. I'm trying to get it working with a web service. So far, it doesn't work, but I think a solution is in there somewhere. Unfortunately, I don't quite know what the exact parameters should be, so it's a bit of hit and miss. (mostly miss) In the code (below), it always falls into the "readyState == 4" condition. I can see in the alert text that it's trying to run "Howdy.asmx? op=HelloWorld", which is hopefully correct. I have tried calling it from the codebehind, and it works, so I'm pretty sure the asmx is fine. I don't want to leave it in the codebehind, because it has to load the viewstate to get in there. Running directly from the javascript seems like the way to go. If you spot something wrong in the code, or if there is a better technique, please let me know. var soapHeader = '<?xml version="1.0" encoding="utf-8"?>' soapHeader += '<soap:Envelope xmlns:xsi="http://www.w3.org/2001/ XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">' soapHeader += '<soap:Body><HelloWorld /></soap:Body></soap:Envelope>' var postUrl = 'Howdy.asmx'; var soapActionUrl = 'HelloWorld'; xmlHTTP = new ActiveXObject("Msxml2.XMLHTTP"); xmlHTTP.open ('GET', postUrl, true); xmlHTTP.onreadystatechange = function() { if ( xmlHTTP.readyState == 4 ) { alert(xmlHTTP.responseText); } }; xmlHTTP.setRequestHeader("Content-Type", "text/xml; charset=utf-8"); xmlHTTP.setRequestHeader("Host", "localhost"); xmlHTTP.setRequestHeader("SOAPAction", soapActionUrl); xmlHTTP.setRequestHeader("Content-Length", soapHeader.length ); xmlHTTP.send(soapHeader); Thanks again Dan |
| | Re: Need a technique to speed up processing Hi Dan, You should have a read of this article.. "dang57" <dan.greitzer@xxxxxx> wrote in message news:071660c2-5032-42fc-94df-7441ad388356@xxxxxx Quote: > Thanks for the suggestion, Adrain. > > I'm trying to get it working with a web service. So far, it doesn't > work, but I think a solution is in there somewhere. Unfortunately, I > don't quite know what the exact parameters should be, so it's a bit of > hit and miss. (mostly miss) > > In the code (below), it always falls into the "readyState == 4" > condition. > I can see in the alert text that it's trying to run "Howdy.asmx? > op=HelloWorld", which is hopefully correct. I have tried calling it > from the codebehind, and it works, so I'm pretty sure the asmx is > fine. I don't want to leave it in the codebehind, because it has to > load the viewstate to get in there. Running directly from the > javascript seems like the way to go. > > If you spot something wrong in the code, or if there is a better > technique, please let me know. > > var soapHeader = '<?xml version="1.0" encoding="utf-8"?>' > soapHeader += '<soap:Envelope xmlns:xsi="http://www.w3.org/2001/ > XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" > xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">' > soapHeader += '<soap:Body><HelloWorld /></soap:Body></soap:Envelope>' > var postUrl = 'Howdy.asmx'; > var soapActionUrl = 'HelloWorld'; > > xmlHTTP = new ActiveXObject("Msxml2.XMLHTTP"); > xmlHTTP.open ('GET', postUrl, true); > xmlHTTP.onreadystatechange = function() { if ( xmlHTTP.readyState == > 4 ) { alert(xmlHTTP.responseText); } }; > xmlHTTP.setRequestHeader("Content-Type", "text/xml; charset=utf-8"); > xmlHTTP.setRequestHeader("Host", "localhost"); > xmlHTTP.setRequestHeader("SOAPAction", soapActionUrl); > xmlHTTP.setRequestHeader("Content-Length", soapHeader.length ); > xmlHTTP.send(soapHeader); > > Thanks again > Dan |
| | Re: Need a technique to speed up processing Well, I'm still struggling with this. The article seems to expect AJAX, but we're not using that. We have Anthem controls. Also, I have a feeling that this might only work with .Net 2.0, but we're still at 1.1. Per the article, I tried adding <asp:ScriptManager>, but it's not recognized by the forms designer. When I don't use the ScriptManager block, the Javascript fails looking for the <namespace>.Howdy. One post indicated that something needed to be added to the web.config, but everything I try adding gets execution errors. Perhaps the blocks don't apply to 1.1. According to the Microsoft knowledgebase, webservices can be used with 1.1, but I can't find any examples of non-AJAX, non-SOAP webservice calls from javascript. I'll keep looking... Thanks Dan |
| | #6 (permalink) |
| | Re: Need a technique to speed up processing I found (what appears to be) a very useful page: http://www.15seconds.com/issue/040708.htm It has walked me through setting up <div id="service" style="BEHAVIOR: url(webservice.htc)" onresult="DisplayResults()"></div> and useService / callService commands. I think it's almost there, except that the actual call returns "fault string = service unavailable". Now trying to figure out why the service is unavailable... (heavy sigh) Dan |
| Speed up the processing of files? | PowerShell | |||
| windows technique | Vista mail | |||
| Expiration Date Technique | .NET General | |||
| Specific folders - What's the best backup technique? | Vista General | |||
| Technique: autoloaded functions | PowerShell | |||
