Vista - Could not defrag my Hard Drive due to Norton Ghost VProSvc.exe
Old 10-11-2008   #1 (permalink)
Duane
I unistalled Norton Ghost 14.0 and when I went to defrag my HD, I got this
error -- basically saying it could not defrag the HD. Here are the specifics
of my results. Any help is appreciated! Thanks. Duane
Volume (C
Volume size = 74.52 GB
Cluster size = 4 KB
Used space = 62.73 GB
Free space = 11.79 GB
Percent free space = 15 %
Volume fragmentation
Total fragmentation = 6 %
File fragmentation = 12 %
Free space fragmentation = 1 %
File fragmentation
Total files = 296,620
Average file size = 389 KB
Total fragmented files = 12
Total excess fragments = 792
Average fragments per file = 1.00
Pagefile fragmentation
Pagefile size = 3.75 GB
Total fragments = 4
Folder fragmentation
Total folders = 22,452
Fragmented folders = 1
Excess folder fragments = 0
Master File Table (MFT) fragmentation
Total MFT size = 411 MB
MFT record count = 320,572
Percent MFT in use = 76 %
Total MFT fragments = 4
Fragments File Size Files that cannot be defragmented
9 363 MB
\WINDOWS\PCHealth\ERRORREP\UserDumps\VProSvc.exe.20081002-041759-00.hdmp
760 1.94 GB \Documents and Settings\Duane\Local
Settings\Application Data\Microsoft\Outlook\Outlook.pst
Old 10-11-2008   #2 (permalink)
PvdG42
Re: Could not defrag my Hard Drive due to Norton Ghost VProSvc.exe
"Duane" <Duane@xxxxxx> wrote in message
news:7C0DEBE2-CCFA-4414-93D9-0B1ABD3E258D@xxxxxx
> specifics
<snip>
You're unlikely to get much help for your defrag issue in this .NET
programming group. You might want to post in a group for your version of
Windows. Here's how to find one.
As you appear to be using a web interface, start here to find an appropriate
group:
http://www.microsoft.com/communities...s/default.aspx
Click the + beside your language. then scroll down to Windows. In Windows,
open the category for your version of Windows, then find a group there to
post in.
Old 10-11-2008   #3 (permalink)
Duane
Thank you will do. Have a good evening.
Regards,
Duane
> > specifics
> <snip>
> group:
> post in.
Ghost/Clone Hard Drive? Vista General
Can't defrag hard drive Vista performance & maintenance
hard drive won't defrag General Discussion
Ghost Icon for USB Toshiba External Hard Drive Vista hardware & devices
transfer data from old xp hard drive to new computer containing Vista Home Premium--Norton Ghost Vista General
