| | Reflection - Difference between DateTime.MaxValue andDecimal.MaxValue I just noticed that, when using intellisense, the DateTime.MaxValue field has a static property icon whereas the Decimal.MaxValue field has a constant property icon. However, when looking at the PropertyInfo data displayed by using reflection against the types, I can see no inherent differences between the properties. How does microsoft determind this difference? Or, how can I determine the difference using reflection? |
| | Re: Reflection - Difference between DateTime.MaxValue and Decimal.MaxValue Joey Fontaine wrote: Quote: > I just noticed that, when using intellisense, the DateTime.MaxValue > field has a static property icon whereas the Decimal.MaxValue field > has a constant property icon. However, when looking at the > PropertyInfo data displayed by using reflection against the types, I > can see no inherent differences between the properties. > fields (so I assume you're talking about FieldInfo). Both are public static initonly fields. Quote: > How does microsoft determind this difference? Or, how can I determine > the difference using reflection? associated with the decimal field (but not the DateTime field). You can verify this yourself by declaring const decimal i = 0.0; static readonly decimal i = 0.0; These produce the same declarations except for the first one having an extra attribute, and VS shows different icons. -- J. |
| | Re: Reflection - Difference between DateTime.MaxValue andDecimal.MaxValue On Oct 13, 1:08*pm, Jeroen Mostert <jmost...@xxxxxx> wrote: Quote: > Joey Fontaine wrote: Quote: > > I just noticed that, when using intellisense, the DateTime.MaxValue > > field has a static property icon whereas the Decimal.MaxValue field > > has a constant property icon. However, when looking at the > > PropertyInfo data displayed by using reflection against the types, I > > can see no inherent differences between the properties. > Neither DateTime.MaxValue nor Decimal.MaxValue are properties, they're > fields (so I assume you're talking about FieldInfo). Both are public static > initonly fields. > Quote: > > How does microsoft determind this difference? Or, how can I determine > > the difference using reflection? > This is a guess, but VS might be using the DecimalConstantAttribute > associated with the decimal field (but not the DateTime field). You can > verify this yourself by declaring > > * *const decimal i = 0.0; > * *static readonly decimal i = 0.0; > > These produce the same declarations except for the first one having an extra > attribute, and VS shows different icons. > > -- > J. IsStatic properties of the FieldInfo class along with the CustomConstantAttribute, DecimalConstantAttribute and DateTimeConstantAttribute located in the System.Runtime.CompilerServices namespace in order to determine if a FieldInfo object is a constant. Thanks! |
| Question on Reflection | .NET General | |||
| Rounding of a [datetime] | PowerShell | |||
| bug in string<->datetime conversion? | PowerShell | |||
| How to use [datetime]::now properly? | PowerShell | |||
| RC2 DateTime casting | PowerShell | |||
