| | Volume errors I tried to update Vista OS to Vista SP1, when system restarts during installation it checks disk volume for errors, in the process of scaning disk if finds some errors as follows: Checking file system on C: The type of the file system is NTFS. Volume label is C-Win Vista. Windows will now check the disk. 232832 file records processed. 766 large file records processed. 0 bad file records processed. 2 EA records processed. 42 reparse records processed. Unable to locate the file name attribute of index entry hmmapi.dll of index $I30 with parent 0x12f32 in file 0x196c0. Deleting index entry hmmapi.dll in index $I30 of file 77618. Unable to locate the file name attribute of index entry FirewallSettings.exe of index $I30 with parent 0x14e92 in file 0x25b92. Deleting index entry FirewallSettings.exe in index $I30 of file 85650. 787812 index entries processed. CHKDSK is recovering lost files. Recovering orphaned file hmmapi.dll (104128) into directory file 77618. Recovering orphaned file FirewallSettings.exe (154514) into directory file 85650. 7 unindexed files processed. 232832 security descriptors processed. Cleaning up 12 unused index entries from index $SII of file 0x9. Cleaning up 12 unused index entries from index $SDH of file 0x9. Cleaning up 12 unused security descriptors. 24024 data files processed. CHKDSK is verifying Usn Journal... 36097272 USN bytes processed. Usn Journal verification completed. CHKDSK is verifying file data (stage 4 of 5)... 232816 files processed. File data verification completed. CHKDSK is verifying free space (stage 5 of 5)... 61845636 free clusters processed. Free space verification is complete. Windows has made corrections to the file system. 312450008 KB total disk space. 64475416 KB in 156028 files. 78276 KB in 24025 indexes. 0 KB in bad sectors. 513772 KB in use by the system. 65536 KB occupied by the log file. 247382544 KB available on disk. 4096 bytes in each allocation unit. 78112502 total allocation units on disk. 61845636 allocation units available on disk. Internal Info: 80 8d 03 00 5f bf 02 00 b4 78 04 00 00 00 00 00 ...._....x...... 8b 05 00 00 2a 00 00 00 8c 08 00 00 00 00 00 00 ....*........... fa 55 d2 0e 00 00 00 00 4d d4 6c 48 00 00 00 00 .U......M.lH.... d8 fb da 2c 00 00 00 00 98 3e 6d b2 03 00 00 00 ....,.....>m..... 60 9a ac 5f 04 00 00 00 bc b0 cb 9c 08 00 00 00 `.._............ 40 78 7d 01 00 00 00 00 c0 1f 01 00 20 43 3c 00 @x}......... C<. 20 bc 45 00 10 00 00 00 34 1d 01 00 60 44 3c 00 .E.....4...`D<. Windows has finished checking your disk. Please wait while your computer restarts. Now, when it restarts I get an error "!!0xc090036!! 7111/75512 hmmapi.dll" then it does not continue booting. I had to restore from a full backup the entire system. Any idea ? I will appreciate your help Thanks, Charles-II |
| | Re: Volume errors "Custom" <Custom@xxxxxx> wrote in message news:10FF74E1-8C4C-425B-B2BE-C53072B9379F@xxxxxx Quote: > I tried to update Vista OS to Vista SP1, when system restarts during > installation it checks disk volume for errors, in the process of scaning > disk > if finds some errors as follows: > > Checking file system on C: The type of the file system is NTFS. Volume > label > is C-Win Vista. Windows will now check the disk. 232832 file records > processed. 766 large file records processed. 0 bad file records processed. > 2 > EA records processed. 42 reparse records processed. Unable to locate the > file > name attribute of index entry hmmapi.dll of index $I30 with parent 0x12f32 > in > file 0x196c0. Deleting index entry hmmapi.dll in index $I30 of file 77618. > Unable to locate the file name attribute of index entry > FirewallSettings.exe > of index $I30 with parent 0x14e92 in file 0x25b92. Deleting index entry > FirewallSettings.exe in index $I30 of file 85650. 787812 index entries > processed. CHKDSK is recovering lost files. Recovering orphaned file > hmmapi.dll (104128) into directory file 77618. Recovering orphaned file > FirewallSettings.exe (154514) into directory file 85650. 7 unindexed files > processed. 232832 security descriptors processed. Cleaning up 12 unused > index > entries from index $SII of file 0x9. Cleaning up 12 unused index entries > from > index $SDH of file 0x9. Cleaning up 12 unused security descriptors. 24024 > data files processed. CHKDSK is verifying Usn Journal... 36097272 USN > bytes > processed. Usn Journal verification completed. CHKDSK is verifying file > data > (stage 4 of 5)... 232816 files processed. File data verification > completed. > CHKDSK is verifying free space (stage 5 of 5)... 61845636 free clusters > processed. Free space verification is complete. Windows has made > corrections > to the file system. 312450008 KB total disk space. 64475416 KB in 156028 > files. 78276 KB in 24025 indexes. 0 KB in bad sectors. 513772 KB in use by > the system. 65536 KB occupied by the log file. 247382544 KB available on > disk. 4096 bytes in each allocation unit. 78112502 total allocation units > on > disk. 61845636 allocation units available on disk. Internal Info: 80 8d 03 > 00 > 5f bf 02 00 b4 78 04 00 00 00 00 00 ...._....x...... 8b 05 00 00 2a 00 00 > 00 > 8c 08 00 00 00 00 00 00 ....*........... fa 55 d2 0e 00 00 00 00 4d d4 6c > 48 > 00 00 00 00 .U......M.lH.... d8 fb da 2c 00 00 00 00 98 3e 6d b2 03 00 00 > 00 > ...,.....>m..... 60 9a ac 5f 04 00 00 00 bc b0 cb 9c 08 00 00 00 > `.._............ 40 78 7d 01 00 00 00 00 c0 1f 01 00 20 43 3c 00 > @x}......... > C<. 20 bc 45 00 10 00 00 00 34 1d 01 00 60 44 3c 00 .E.....4...`D<. > Windows > has finished checking your disk. Please wait while your computer restarts. > > Now, when it restarts I get an error "!!0xc090036!! 7111/75512 hmmapi.dll" > then it does not continue booting. I had to restore from a full backup the > entire system. > > Any idea ? > I will appreciate your help > Thanks, > Charles-II in this .NET programming group. You'll get a lot more help if you do the following... As you appear to be using a web interface, start here to find an appropriate group: http://www.microsoft.com/communities...s/default.aspx Click the + beside your language. then scroll down to Windows. In Windows, open the category for Windows Vista, then find a group there to post in. |
| Stop Errors - Troubleshooting Specific Stop Errors | Tutorials | |||
| Updating Vista SP1 - Volume errors | Vista General | |||
| Errors, errors and more errors - I have Issues! | Vista performance & maintenance | |||
| Red X on Volume Icon and Volume Mixer has disappeared | Vista General | |||
| explorer errors, program errors, no task manager | Vista performance & maintenance | |||
