Vista - Print Screen using Vista
Old 10-24-2008   #1 (permalink)
n8
This may be the stupidest question ever, but how does the "print screen" work
on Vista? I've tried every possible thing with Shift, Ctrl, Alt..... Still
seeking the resolution.
Old 10-24-2008   #2 (permalink)
Miro
Re: Print Screen using Vista
this is a programmign group - but to answer your question -
its Alt-PrintScreen - and it puts the pictuer of your desktop into your
clipboard to be pasted anywhere.
Now, if you have a laptop - you probably have to hit something like
Alt+FunctionKey+Printscreen, if the printscreen button is on a 'secondary
button'
Miro
"n8" <n8@xxxxxx> wrote in message
news:F8F11914-9A09-4C02-9AF3-434AED7CCAD2@xxxxxx
> work
> Still
Old 10-24-2008   #3 (permalink)
Mark Salsbery [MVP]
> work
> Still
Ctl-PrtScn gets the entire desktop
Alt-PrtScn gets the active top-level window
Some keyboards (like mine) you need to turn FLock off to get at the PrtScn.
Mark
Mark Salsbery
Microsoft MVP - Visual C++
Old 11-14-2008   #4 (permalink)
mc
wow....alt+function key+printscreen works!
they say for vista there's a snipping tool for capturing a window...but i
couldn't find it either.
thanks a lot for the alt+fn+prtsc.
> button'
> Miro
> > work
> > Still
Old 11-14-2008   #5 (permalink)
Vista Ultimate 32/64 bit
Quote  Quote: Originally Posted by mc View Post
> button'
> Miro
> > work
> > Still
Here ya go ~ How to use the Snipping Tool in Vista
Old 11-15-2008   #6 (permalink)
VISTA HOME PREMIUM X64/ 7 x64 / 7x86
> button'
> Miro
> > work
> > Still
You need Tablet PC installed to get the Snipping Tool. Don't think you get it in Home Basic.
If you have one of the other editions, ControlPanel>Uninstall a Program and on the left of that window, Turn Windows features on or off.
Faststone Capture53 is an excellent free screen capture app.
FastStone Capture 5.3 - eSnips, share anything
Hope it helps
SIW2
How to print screen on a keyboard without print screen button? .NET General
Vista print screen help Vista General
Screen print vista Vista General
can't print screen with vista Vista General
Vista screen print Vista General
