| | ClickOnce 404 problem I have used ClickOnce to deploy my app to a file share on a server in my intranet. That folder is under a webserver root so I want my users to go to http://someserver.dom.com/App/Publish.htm and to get the app from there. This does not work. The initial MyApp.application is downloaded, but it is unable to download the rest of the files. The logs all indicate a 404 (Not Found) error. Looking in the webserver logs, it is trying to download files that have "App/Application+Files/App_1_0_0_10/" in them. I have no idea why the plus sign is in there. It should be a space or a %20. I am unable to find how VS generates the Application Files path, so I can change it to something else, it seems to be hard-coded. Any ideas? - Lutz |
| | RE: ClickOnce 404 problem Hi Lutz, Thank you for using Microsoft Managed Newsgroup Service, my name is Zhi-Xin Ye, I'm assigned to help you on this issue. The "404(Not Found)" error is often caused by impoper server configurations. If you use Internet Information Services (IIS) on Windows Server 2003, and your deployment contains a file type that Windows does not recognize, such as a Microsoft Word file, IIS will refuse to transmit that file, and your deployment will not succeed. So you can verify that the Web server is configured so that it does not block download of this file. For more information, you can refer to these document: Server and Client Configuration Issues in ClickOnce Deployments http://msdn.microsoft.com/en-us/library/ms228998.aspx Please try my suggestion and let me know the result. Sincerely, Zhi-Xin Ye Microsoft Managed Newsgroup Support Team Delighting our customers is our #1 priority. We welcome your comments and suggestions about how we can improve the support we provide to you. Please feel free to let my manager know what you think of the level of service provided. You can send feedback directly to my manager at: msdnmg@xxxxxx. ================================================== Get notification to my posts through email? Please refer to http://msdn.microsoft.com/en-us/subs...#notifications. Note: MSDN Managed Newsgroup support offering is for non-urgent issues where an initial response from the community or a Microsoft Support Engineer within 2 business day is acceptable. Please note that each follow up response may take approximately 2 business days as the support professional working with you may need further investigation to reach the most efficient resolution. The offering is not appropriate for situations that require urgent, real-time or phone-based interactions. Issues of this nature are best handled working with a dedicated Microsoft Support Engineer by contacting Microsoft Customer Support Services (CSS) at http://msdn.microsoft.com/en-us/subs.../aa948874.aspx ================================================== This posting is provided "AS IS" with no warranties, and confers no rights. |
| | Re: RE: ClickOnce 404 problem None of the three extensions are blocked. Any other ideas? Why is there a plus sign in the path instead of a %20? - Lutz |
| | Re: RE: ClickOnce 404 problem Hi Lutz, I don't think the plus sign causes the problem, I check my web logs and see the plus sign in the path, but the application is downloaded successfully. Would you please collect the following information at your earliest convenience? It will help me get a more concrete idea as to what the exact problem is and how to resolve it efficiently. 1. Which operating system is used on your server? 2. Which Web server is running on the server? Internet Information Service(IIS) or third-party web servers? 3. Which .NET Framework version is used on the server? 4. When you deploy the application, did you set the "Publishing Folder Location" to the file share on the server, and set the "Installation Folder URL" to the URL that for the users to install? Anyway, you can check on the server to make sure: 1. The following MIME types are set up correctly on the server: .application --> application/x-ms-application .manifest --> application/x-ms-application .deploy --> application/octet stream 2. Regular users have read access to the root deployment folder and all the files and folders within. I look forward to hearing from you. Sincerely, Zhi-Xin Ye Microsoft Managed Newsgroup Support Team Delighting our customers is our #1 priority. We welcome your comments and suggestions about how we can improve the support we provide to you. Please feel free to let my manager know what you think of the level of service provided. You can send feedback directly to my manager at: msdnmg@xxxxxx. This posting is provided "AS IS" with no warranties, and confers no rights. |
| ClickOnce | Vista security | |||
| clickonce | .NET General | |||
| ClickOnce - Is it right for me? | .NET General | |||
| ClickOnce exception in IE | .NET General | |||
| ClickOnce Deployment (BUG?) | .NET General | |||
