Vista - SqlBulkcopy memory leak problem
Old 11-05-2008   #1 (permalink)
Sergey Zenyuk
In VB.net windows application I use following
code implementing SqlBulkCopy import:
Using connODBC As New OdbcConnection(ConnStrODBC)
connODBC.Open()
Dim dbcmd As New OdbcCommand(String.
Format("select * from {0}", TableName), connODBC)
dbcmd.CommandTimeout = SQL_TIMEOUT
bulkcopy.WriteToServer(dbcmd.ExecuteReader())
connODBC.Close()
connODBC.Dispose()
End Using
with connection string:
Dim connbuilderODBC As New OdbcConnectionStringBuilder()
connbuilderODBC("Driver") = "{Microsoft Visual FoxPro
Driver}"
connbuilderODBC("SourceType") = "DBF"
connbuilderODBC("SourceDB") = Path.
GetDirectoryName(DBFileName)
connbuilderODBC("Exclusive") = "No"
ConnStrODBC = connbuilderODBC.ConnectionString
this code leak to memory leak problems on big files.
After visual studio closing memory is busy.
Please,help
Old 11-05-2008   #2 (permalink)
Jani Järvinen [MVP]
Re: SqlBulkcopy memory leak problem
Hi Sergey,
> connODBC.Open()
> connODBC.Close()
> connODBC.Dispose()
> End Using
How are you measuring the memory usage and leaking? One thing that is most
probably the major factor is that you let the .NET garbage collector to
collect memory for the OdbcCommand, OdbcDataReader and the SqlBulkCopy
instances.
All these implement the IDisposable interface, so you should call their
Dispose methods if you want to make sure the memory is freed as soon as
possible. If you don't this, you might observe the said leak.
Regards,
Mr. Jani Järvinen
C# MVP
Vantaa, Finland
janij@xxxxxx
http://www.saunalahti.fi/janij/
Vista Sp1 Memory Leak problem Vista General
Memory Leak problem with AUDIODG.EXE ! Need help Sound & Audio
Memory leak problem using sqlBulkCopy .NET General
Memory Leak General Discussion
Memory leak Vista General
