Vista - >>web reference
Old 11-06-2008   #1 (permalink)
Jonathan
>>web reference
Hi, in a visual studio vb.net 2008 windows application I want to talk to a
web service set up in bizTalk. When setting the reference 4 methods are
listed. However once I add this reference and view in the object browser this
reference does not expand to show these methods that I want to use. Instead
the list has its objects.
As you may have guessed I'm new to this and so any ideas or suggestions are
appreciated :-)
Many thanks, Jonathan
add a reference .NET General
To Reference Interop.XXX.dll or XXX.dll .NET General
Best Reference PowerShell
Best reference for .NET for use with PS PowerShell
