| | Empty Project in Visual Studio 2008 I installed Visual Studio 2008 Express Edition. I created a new project and picked "Empty Project" as project type. Then I don't see any file in this project. Normally Visual Studio would present a default file with a "main". However, I don't see any default method/file. Any advice on what to do the next? |
| | Re: Empty Project in Visual Studio 2008 It sounds like you created an empty solution, not an empty project. Right click on the solution, and add a project. "Curious" <fir5tsight@xxxxxx> wrote in message news:042a952c-7a35-49c9-bcf9-184c389eb17c@xxxxxx Quote: >I installed Visual Studio 2008 Express Edition. > > I created a new project and picked "Empty Project" as project type. > > Then I don't see any file in this project. Normally Visual Studio > would present a default file with a "main". However, I don't see any > default method/file. > > Any advice on what to do the next? |
| | Re: Empty Project in Visual Studio 2008 Family Tree Mike, There is a project in the solution: Solution: Solution 'Swings' (1 project) Underneath it is the project, Swings. However, there is only "References" underneath the project. No .cs file. I've never used "Empty Project" option (it seems that it's only in Visual Studio 2008). I was told that "Empty Project" is similar to "Console Application" in VS 2008. However, there's a default "Program.cs" created in a "Console Application" project, but there is none in "Empty Project". Could it be that this is a bug in VS 2008? |
| | Re: Empty Project in Visual Studio 2008 Does it allow you to right click and add a form to the project? "Curious" <fir5tsight@xxxxxx> wrote in message news:2d1275de-cd44-4f90-a1ed-726bcc0c7113@xxxxxx Quote: > Family Tree Mike, > > There is a project in the solution: > > Solution: Solution 'Swings' (1 project) > Underneath it is the project, Swings. > > However, there is only "References" underneath the project. No .cs > file. > > I've never used "Empty Project" option (it seems that it's only in > Visual Studio 2008). I was told that "Empty Project" is similar to > "Console Application" in VS 2008. However, there's a default > "Program.cs" created in a "Console Application" project, but there is > none in "Empty Project". > > Could it be that this is a bug in VS 2008? |
| | Re: Empty Project in Visual Studio 2008 Sorry, I had never even noticed that project type. Now seeing it, I can't say it is a bug, because it is "empty". I would say however it seems fairly useless to me. "Curious" <fir5tsight@xxxxxx> wrote in message news:2d1275de-cd44-4f90-a1ed-726bcc0c7113@xxxxxx Quote: > Family Tree Mike, > > There is a project in the solution: > > Solution: Solution 'Swings' (1 project) > Underneath it is the project, Swings. > > However, there is only "References" underneath the project. No .cs > file. > > I've never used "Empty Project" option (it seems that it's only in > Visual Studio 2008). I was told that "Empty Project" is similar to > "Console Application" in VS 2008. However, there's a default > "Program.cs" created in a "Console Application" project, but there is > none in "Empty Project". > > Could it be that this is a bug in VS 2008? |
| | #6 (permalink) |
| | Re: Empty Project in Visual Studio 2008 Hi Miro, Yes, it allows me to add a class/form to the project. Maybe I should start from there? |
| | #7 (permalink) |
| | Re: Empty Project in Visual Studio 2008 Miro, I've added a "Code File" and put in the following code: static Main () { } However, it doesn't compile. Compilation error is below: Expected class, delegate, enum, interface, or struct If I add a Class, that wouldn't work, either, because it asks for an Main as entry point of the program. I don't prefer to use this type of project, but the associate I work with prefers this type. |
| Create Project.resources.dll like Visual Studio | .NET General | |||
| Visual Studio 2008 Link Error for VS6.0 Project | .NET General | |||
| PowerShell Visual Studio project template wiped out all other templates | PowerShell | |||
| Visual Studio Shuts Down Unexpectedly When Loading Project - ASP.NET Web Application running against IIS | .NET General | |||
| Tool To Create Function Map Of C#.NET Project In Visual Studio 200 | .NET General | |||
