Vista - Why won't generatePublisherEvidence app setting speed up load time
Old 11-17-2008   #1 (permalink)
masix
We have an issue with load time in several installations of our application.
We've located the information regarding KB 936707 and ensured that the
application config file contains the runtime setting of
<generatePublisherEvidence enabled="false"/>
but the application still takes over 2 minutes to load. When we disconnect
the PC from the network (internet) then the application loads in about 5
seconds.
We've ensured the .net 2.0 version is SP1 - which should allow this to work.
Does anyone know of any other way to ensure this timeout to the crl doesn't
occur and our application will load normally?
MSix
Senior Developer
AGCO Corporation
Old 11-17-2008   #2 (permalink)
John Vottero
Re: Why won't generatePublisherEvidence app setting speed up load time
You need .NET V3.5 SP1
"masix" <masix@xxxxxx> wrote in message
news:6BF666CD-011E-43AD-8DCC-52F07432C8C8@xxxxxx
> application.
> disconnect
> seconds.
> work.
> doesn't
> MSix
> Senior Developer
> AGCO Corporation
Old 11-18-2008   #3 (permalink)
Hongye Sun [MSFT]
Hi MSix,
Thanks for using Microsoft Newsgroup Service. My name is Hongye Sun [MSFT]
and it is my pleasure to work with you on this issue.
.NET Framework 2.0 SP1 has already included KB 936707 hot fix, so
"generatePublisherEvidence" should be working. Before taking further steps
into this issue, we need to confirm 2 facts:
1. Is the issue caused by KB 936707?
I noticed that you mentioned "several installations of our application". Do
you mean that other installations in other machines work properly? If so,
can you enable generatePublisherEvidence and check if the load time
increases.
Another way is to disable in Internet Explorer -> Options -> Advanced ->
Security -> 'Check for publisher's certificate revocation' check box. This
is also a Per-Machine Workaround for this issue. It will prevent CLR to
checking for certificate for all code-signed assemblies. After uncheck the
setting, check if the problem disappears.
2. Is the .NET Framework 2.0 SP1 installed
First of all, I need to declare that all the machines I mentioned here is
the target machine which the application is installed at, instead of the
development machine.
In the target machine, open registry, find key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v2.0.50727.
Check if the "SP" equals or greater than 1.
Please let me know the results. Thanks.
Regards,
Hongye Sun (hongyes@xxxxxx, remove 'online.')
Microsoft Online Community Support
Delighting our customers is our #1 priority. We welcome your comments and
suggestions about how we can improve the support we provide to you. Please
feel free to let my manager know what you think of the level of service
provided. You can send feedback directly to my manager at:
msdnmg@xxxxxx.
Why IE7 so slow to load web pages ??? How to speed it up ? Vista performance & maintenance
How to change WMP setting from time elapsed to time to go Vista music pictures video
Setting Up 2 High Speed Connections? Vista networking & sharing
mediacenter- music load time way to long, how to speed up? Vista music pictures video
Demo of getting/setting time from an RFC867 time source PowerShell
