| | Is there a way to resize an array from inside a procedure? Using Reflection maybe? I want to write a VB.NET subroutine that will take an input array of arbitrary type and resize it. Here is a trivial example of what I am trying to do: 'Increase the length of an arbitrary input array by one, using ReDim. Public Sub TryToReDim(ByRef ArrayIn As Object()) ReDim Preserve ArrayIn(ArrayIn.Length) End Sub Actually what I really want -- because VB is so braindead when it comes to array manipulation -- is a Perl style Splice() routine, which of course would need to be able to resize the input array. I have a routine like that that works fine in VBA, but when I try to translate it to VB.NET I am tripped up by casting exceptions. Here is an example of the problem: Dim xxx() as String = {"aaa", "bbb", "ccc"} TryToReDim(xxx) This throws the following exception: InvalidCastException occurred Unable to cast object of type 'System.Object[]' to type 'System.String[]'. The problem is that, although the input variable ArrayIn is of type String[], ReDim, instead of redimensioning the array that was passed, creates a new, local array of type Object[], which then can't be assigned back to the original String[] input variable. So what can I do? For example, is there some way that, instead of using ReDim, I could examine the input array, determine its type, and create a properly sized local ArrayIn array of the same type, which could eventually be copied back without problems? I know that there is a such thing as Reflection in .NET, but it's not clear to me how that would apply in this case. For that matter, does VB.NET already have the equivalent of Splice() somewhere, which, for example, would allow me to insert an element into the middle of an array, without having to jump though hoops? I have never understood why it is so awkward to manipulate arrays in VBA and VB.NET! Does anyone have any idea why, after all this time, this hasn't been fixed? -- John Brock jbrock@xxxxxx |
| | Re: Is there a way to resize an array from inside a procedure? Using Reflection maybe? Quote: > "VB is so braindead when it comes to array manipulation" Framework ? imho VB and C# are masters with array manipulation http://msdn.microsoft.com/en-us/libr...tem.array.aspx resizing with the array class http://msdn.microsoft.com/en-us/library/bb348051.aspx and lots and lots more The exception that you encounter is obvious , you might be bether of with generics in your case HTH Michel Posseth "John Brock" <jbrock@xxxxxx> schreef in bericht news:gftga1$f9a$1@xxxxxx Quote: >I want to write a VB.NET subroutine that will take an input array > of arbitrary type and resize it. Here is a trivial example of what > I am trying to do: > > 'Increase the length of an arbitrary input array by one, using ReDim. > Public Sub TryToReDim(ByRef ArrayIn As Object()) > ReDim Preserve ArrayIn(ArrayIn.Length) > End Sub > > Actually what I really want -- because VB is so braindead when it > comes to array manipulation -- is a Perl style Splice() routine, > which of course would need to be able to resize the input array. > I have a routine like that that works fine in VBA, but when I try > to translate it to VB.NET I am tripped up by casting exceptions. > Here is an example of the problem: > > Dim xxx() as String = {"aaa", "bbb", "ccc"} > TryToReDim(xxx) > > This throws the following exception: > > InvalidCastException occurred > Unable to cast object of type 'System.Object[]' to type 'System.String[]'. > > The problem is that, although the input variable ArrayIn is of type > String[], ReDim, instead of redimensioning the array that was > passed, creates a new, local array of type Object[], which then > can't be assigned back to the original String[] input variable. > > So what can I do? For example, is there some way that, instead of > using ReDim, I could examine the input array, determine its type, > and create a properly sized local ArrayIn array of the same type, > which could eventually be copied back without problems? I know > that there is a such thing as Reflection in .NET, but it's not > clear to me how that would apply in this case. > > For that matter, does VB.NET already have the equivalent of Splice() > somewhere, which, for example, would allow me to insert an element > into the middle of an array, without having to jump though hoops? > I have never understood why it is so awkward to manipulate arrays > in VBA and VB.NET! Does anyone have any idea why, after all this > time, this hasn't been fixed? > -- > John Brock > jbrock@xxxxxx > |
| | Re: Is there a way to resize an array from inside a procedure? Using Reflection maybe? "John Brock" <jbrock@xxxxxx> schrieb Quote: > I want to write a VB.NET subroutine that will take an input array of > arbitrary type and resize it. Framework based language. Read also the documentation on Redim Preserve. It creates a new array as you've already pointed out below on your own. Use one of the many other helpful collections: http://msdn.microsoft.com/en-us/library/7y3x785f.aspx (maybe before all "commonly used collections") Quote: > Dim xxx() as String = {"aaa", "bbb", "ccc"} > TryToReDim(xxx) > > This throws the following exception: good enough. Armin |
| | Re: Is there a way to resize an array from inside a procedure? Using Reflection maybe? "John Brock" <jbrock@xxxxxx> wrote in message news:gftga1$f9a$1@xxxxxx Quote: > For that matter, does VB.NET already have the equivalent of Splice() > somewhere, which, for example, would allow me to insert an element > into the middle of an array, without having to jump though hoops? > I have never understood why it is so awkward to manipulate arrays > in VBA and VB.NET! Does anyone have any idea why, after all this > time, this hasn't been fixed? of memory as Armin pointed out. You should be using one of the many collection classes if you want to insert items in the middle of a list. Most likely the List class is what you need as it has an insert method. The list class is generic so can be created as type string Dim list as New List(Of String) list.add("Aa") list.add("ba") list.add("va") list.add("da") list.Insert("aaaa", 3") Michael |
| | Re: Is there a way to resize an array from inside a procedure? Using Reflection maybe? "John Brock" <jbrock@xxxxxx> wrote in message news:gftga1$f9a$1@xxxxxx Quote: >I want to write a VB.NET subroutine that will take an input array > of arbitrary type and resize it. Here is a trivial example of what > I am trying to do: > > 'Increase the length of an arbitrary input array by one, using ReDim. > Public Sub TryToReDim(ByRef ArrayIn As Object()) > ReDim Preserve ArrayIn(ArrayIn.Length) > End Sub > > Actually what I really want -- because VB is so braindead when it > comes to array manipulation -- is a Perl style Splice() routine, > which of course would need to be able to resize the input array. > I have a routine like that that works fine in VBA, but when I try > to translate it to VB.NET I am tripped up by casting exceptions. > Here is an example of the problem: > > Dim xxx() as String = {"aaa", "bbb", "ccc"} > TryToReDim(xxx) > > This throws the following exception: > > InvalidCastException occurred > Unable to cast object of type 'System.Object[]' to type 'System.String[]'. > > The problem is that, although the input variable ArrayIn is of type > String[], ReDim, instead of redimensioning the array that was > passed, creates a new, local array of type Object[], which then > can't be assigned back to the original String[] input variable. > > So what can I do? For example, is there some way that, instead of > using ReDim, I could examine the input array, determine its type, > and create a properly sized local ArrayIn array of the same type, > which could eventually be copied back without problems? I know > that there is a such thing as Reflection in .NET, but it's not > clear to me how that would apply in this case. > > For that matter, does VB.NET already have the equivalent of Splice() > somewhere, which, for example, would allow me to insert an element > into the middle of an array, without having to jump though hoops? > I have never understood why it is so awkward to manipulate arrays > in VBA and VB.NET! Does anyone have any idea why, after all this > time, this hasn't been fixed? > -- > John Brock > jbrock@xxxxxx > collections classes in .NET. It's easy to convert your array to a List<>, then do any resizing needed, then convert the List<> back to an array if you must have it as an array. Look up the collections classes in MSDN and observe all the management methods available. |
| | #6 (permalink) |
| | Re: Is there a way to resize an array from inside a procedure? Using Reflection maybe? On 2008-11-18, John Brock <jbrock@xxxxxx> wrote: Quote: > I want to write a VB.NET subroutine that will take an input array > of arbitrary type and resize it. Here is a trivial example of what > I am trying to do: > > 'Increase the length of an arbitrary input array by one, using ReDim. > Public Sub TryToReDim(ByRef ArrayIn As Object()) > ReDim Preserve ArrayIn(ArrayIn.Length) > End Sub > > Actually what I really want -- because VB is so braindead when it > comes to array manipulation -- is a Perl style Splice() routine, > which of course would need to be able to resize the input array. > I have a routine like that that works fine in VBA, but when I try > to translate it to VB.NET I am tripped up by casting exceptions. > Here is an example of the problem: > > Dim xxx() as String = {"aaa", "bbb", "ccc"} > TryToReDim(xxx) > > This throws the following exception: > > InvalidCastException occurred > Unable to cast object of type 'System.Object[]' to type 'System.String[]'. > > The problem is that, although the input variable ArrayIn is of type > String[], ReDim, instead of redimensioning the array that was > passed, creates a new, local array of type Object[], which then > can't be assigned back to the original String[] input variable. > > So what can I do? For example, is there some way that, instead of > using ReDim, I could examine the input array, determine its type, > and create a properly sized local ArrayIn array of the same type, > which could eventually be copied back without problems? I know > that there is a such thing as Reflection in .NET, but it's not > clear to me how that would apply in this case. > > For that matter, does VB.NET already have the equivalent of Splice() > somewhere, which, for example, would allow me to insert an element > into the middle of an array, without having to jump though hoops? > I have never understood why it is so awkward to manipulate arrays > in VBA and VB.NET! Does anyone have any idea why, after all this > time, this hasn't been fixed? Option Explicit On Option Strict On Imports System Imports System.Collections.Generic Module Module1 Sub Main() Dim arr() As String = {"aaa", "ccc"} Console.WriteLine("==================== Before ======================") Array.ForEach(arr, AddressOf PrintElement) Console.WriteLine("==================================================") arr = Splice(Of String)(arr, "bbb", 1) Console.WriteLine("===================== After ======================") Array.ForEach(arr, AddressOf PrintElement) Console.WriteLine("==================================================") End Sub Sub PrintElement(ByVal element As String) Console.WriteLine(element) End Sub Function Splice(Of T)(ByVal arr() As T, ByVal item As T, ByVal index As Integer) As T() Dim l As New List(Of T)(arr) l.Insert(index, item) Return l.ToArray() End Function End Module That implementation of splice, is well very naive - there are no error checks or anything But, as others have already said, I think what you really shouldbe looking at are Generics and the Generic colleciton classes. They are much more flexible. -- Tom Shelton |
| | #7 (permalink) |
| | Re: Is there a way to resize an array from inside a procedure? Using Reflection maybe? In article <20C1914E-56BC-4D44-8AED-A3BDCADC8E7E@xxxxxx>, PvdG42 <pvdg42@xxxxxx> wrote: Quote: >Brain dead? As you've been told, you need exposure to the various >collections classes in .NET. >It's easy to convert your array to a List<>, then do any resizing needed, >then convert the List<> back to an array if you must have it as an array. >Look up the collections classes in MSDN and observe all the management >methods available. suggestion will certainly work, but it's a pain. In fact it is actually an perfect example of just the sort of hoop I've been hoping to avoid having to jump through when it comes time to do anything with arrays. It's always possible I've missed something though. An example might be helpful! Let's say that, for the array below, I wanted to insert an additional element, "xxx" perhaps, in the second position. Is there a one line VB.NET statement that will do this? (If possible the statement should be general, so that it will work equally well if I want to use it for an array of Integers, or other types). Dim xxx() as String = {"aaa", "bbb", "ccc"} This is something which is trivially easy in Perl, and, IMO, ought to be easy in any well designed language. If you can't come up with a one line example, then a two or three line example would also be welcome. Actually, I'd be interested in seeing how you would handle this situation if it came up in your own code. Don't tell me though that I ought to be using lists instead of arrays. For one thing, I might be dealing with existing code, and not have that option. In any case, unless you are saying arrays in .NET are totally deprecated and should never be used, there is always the possibility that you will find yourself using arrays because they are the best choice for a particular situation, and then finding that you need to insert elements into the middle of those arrays. So how -- in a general way -- does one do that? If in fact there is no easy way I'd still be interested in knowing why. It's possible there is some deep legacy issue which prevents Microsoft from making the obvious additions to the language, but I'd be interested in knowing what that issue is. -- John Brock jbrock@xxxxxx |
| | #8 (permalink) |
| | Re: Is there a way to resize an array from inside a procedure? Using Reflection maybe? "John Brock" <jbrock@xxxxxx> schrieb Quote: > Is there a one line VB.NET statement that will do this? > (If possible the statement should be general, so that it will work > equally well if I want to use it for an array of Integers, or other > types). > > Dim xxx() as String = {"aaa", "bbb", "ccc"} > > This is something which is trivially easy in Perl, and, IMO, ought > to be easy in any well designed language. If you can't come up > with a one line example, then a two or three line example would > also be welcome. Actually, I'd be interested in seeing how you > would handle this situation if it came up in your own code. However, as there are other ways to do what you want in the .Net world, why do you insist on doing it with an array? It is as if I'd use Perl and insist on using a List(Of) there but it doesn't exist. You've simply chosen the wrong type for your purposes. Armin |
| | #9 (permalink) |
| | Re: Is there a way to resize an array from inside a procedure? Using Reflection maybe? > You've simply chosen the wrong type for your purposes. I mean, you have made a wrong translation. "Array" in the Perl language translated to VB.Net is "List(Of)". You translated it to "Array". That's obviously wrong. Armin |
| | #10 (permalink) |
| | Re: Is there a way to resize an array from inside a procedure? Using Reflection maybe? On 2008-11-19, John Brock <jbrock@xxxxxx> wrote: Quote: > In article <20C1914E-56BC-4D44-8AED-A3BDCADC8E7E@xxxxxx>, > PvdG42 <pvdg42@xxxxxx> wrote: > Quote: >>Brain dead? As you've been told, you need exposure to the various >>collections classes in .NET. >>It's easy to convert your array to a List<>, then do any resizing needed, >>then convert the List<> back to an array if you must have it as an array. >>Look up the collections classes in MSDN and observe all the management >>methods available. > Um, I think "braindead" is in fact the appropriate word here. Your > suggestion will certainly work, but it's a pain. In fact it is > actually an perfect example of just the sort of hoop I've been > hoping to avoid having to jump through when it comes time to do > anything with arrays. > Quote: > It's always possible I've missed something though. An example > might be helpful! Let's say that, for the array below, I wanted > to insert an additional element, "xxx" perhaps, in the second > position. Is there a one line VB.NET statement that will do this? > (If possible the statement should be general, so that it will work > equally well if I want to use it for an array of Integers, or other > types). > > Dim xxx() as String = {"aaa", "bbb", "ccc"} > > This is something which is trivially easy in Perl, and, IMO, ought > to be easy in any well designed language. If you can't come up > with a one line example, then a two or three line example would > also be welcome. Actually, I'd be interested in seeing how you > would handle this situation if it came up in your own code. > a C-style fixed size chunk of memory. In .NET, Arrays are essentially that - fixed chunk of memory. If you insist on using arrays rather then the collection classes (such as List(Of T)) then you will want to understand this implementation so that you can efficiently work with them. First, you should understand what ReDim does, it creates a new array - basically it allocates a new chunk of memory, and if you specify preserve, then it copies the values of the old array to the new array. That's fine and good, but is very inefficient if you are going to make a lot of calls to ReDim. So, you will want to grow the array more then needed to keep the calls to ReDim to a minimum. The common algorith is to increase the size by 10% of the current size with each allocation. Of course, this posess a problem... Because the size of the array and the number of elements are out of sync - so, you probably will want to introduce a variable to keep track of the actual number of values stored in the array. Another consideration is the addition and removal of items. Generally, that means shifting things around - either up or down in the array, setting the unused slots to nothing, and then updating your element counter... It's a lot of work, so, to keep from making a mistake, you might want to wrap this all in a class that can handle the management of the array. Then provide a method to get an actual array when you need it. Oh, or you could just use List(Of T) - because that's exactly what it does. List(Of T) is a wrapper for an array, that handles all of the managment details for you. Quote: > Don't tell me though that I ought to be using lists instead of > arrays. takes an IEnumerable(Of T) in one of it's constructors (which System.Array implements) and it has a .ToArray method. Quote: > For one thing, I might be dealing with existing code, and > not have that option. Quote: > In any case, unless you are saying arrays > in .NET are totally deprecated and should never be used, there is > always the possibility that you will find yourself using arrays > because they are the best choice for a particular situation, and > then finding that you need to insert elements into the middle of > those arrays. So how -- in a general way -- does one do that? > > If in fact there is no easy way I'd still be interested in knowing > why. It's possible there is some deep legacy issue which prevents > Microsoft from making the obvious additions to the language, but > I'd be interested in knowing what that issue is. very effiecient - if they don't need to be changed much. If the data is not static in it's size, then managing an array in an efficient manner becomes a not so trivial exercise... Hence, System.Collections.ArrayList and System.Collections.Generic.List(Of T) - you should prefere List(Of T) over ArrayList in new code because of the improved functionality and the performance benifits of generics. HTH -- Tom Shelton |
| How to programmatically resize the height of a custom IE toolbarwritten in C#? When I resize it, it shrinks but the real-estate it is in staysthe same size. | .NET General | |||
| VB script - for accessing a array returned from stored procedure | VB Script | |||
| how to retrieve an array returned from stored procedure | VB Script | |||
| Property Set procedure with a structure array | .NET General | |||
| can't remember how to resize an array | PowerShell | |||
