Vista - Ready Boost new problem
Old 11-20-2008   #1 (permalink)
Atacayte
Hi
I bought a new Pen ReadyBoost compatible, and when I connect it to my
Laptop, Ready Boost tells me that already exist a cache device and cannot use
my new Pen to such a purpouse... well, I don´t remember to have activated RB
with any other device never before because I haven`t any compatible, but in
fact I can't disable neither enable RB to use it now... what can I do?, is
there a way to reset RB from previous unknown activation?
Thnx
Old 11-21-2008   #2 (permalink)
PvdG42
Re: Ready Boost new problem
"Atacayte" <Atacayte@xxxxxx> wrote in message
news:7197DA3A-6AEA-4511-842C-30DD0D32E154@xxxxxx
Quote:
> Hi
> use
> RB
> in
> Thnx
You'll get a lot more interest and help with your issue in a Vista group,
rather than in this .NET programming group.
Here's how to find the discussion group you need.
As you appear to be using a web interface, start here:
http://www.microsoft.com/communities...s/default.aspx
In the tree on the left, first open the English category, then open Windows.
In Windows, find and open the Windows Vista category, then locate a group to
post in.
Ready Boost General Discussion
Problem with Ready Boost Using Memory Stick Pro Duo Vista performance & maintenance
SD / Ready Boost ? Vista performance & maintenance
Need help with Ready Boost Vista General
Does Ready Boost use a lot of CPU? Vista performance & maintenance
