| | SCOm 2007 agent problem hi to all, i have a problem with scom 2007 that i install it with sql 2005 on same server (windows server 2003 with SP2) successfully but the agent cant install well that if it succus install on remote server it appear on pending management with status installation in progress and if failed it appear a failed on pending management and i try the following : 1. set the action account and SK service and config account as domain admin or local services account 2. Install a scom SP1 3. Reinstall a scom and sql server 2005 4. check a SPN on scom server 5.change a sql services running account And the problem didn't solve yet -- Thanks -- Thanks |
| Use PowerShell to trigger SCOM reporting? | PowerShell | |||
| agent.exe? | Vista General | |||
| Problem with Vista/Office 2007 & SharePoint 2007 | Vista networking & sharing | |||
| ms agent | PowerShell | |||
| Modem / Internet / RealConnect Agent problem | Vista installation & setup | |||
