Vista - Problem with XmlTextWriter WriteFullEndElement method
Old 11-24-2008   #1 (permalink)
M1iS
I’m having a problem with writing full end elements on elements that are
supposed to be empty strings. I’m calling the WriteFullEndElement method on
my elements that are supposed to be empty however it is still creating a self
closing tag. My code is posted below.
Thanks,
Scott
//build xml document
XmlTextWriter xw = new XmlTextWriter(docFullName, Encoding.UTF8);
xw.WriteStartDocument();
xw.WriteStartElement(app.XmlRootName);
xw.WriteAttributeString("version", DateTime.Now.ToShortDateString());
//get application translations
DataTable translations =
ApplicationController.GetTranslations(ApplicationID);
int currentLanguageID = 0;
int languageID;
string languageName;
string languageCode;
string resourceCode;
string translation;
bool isFirstLanguageElement = true;
bool isEmpty;
int counter = 0;
foreach (DataRow t in translations.Rows)
languageID = (int)t["LanguageID"];
languageName = t["LanguageName"].ToString();
languageCode = t["LanguageCode"].ToString();
resourceCode = t["ResourceCode"].ToString();
translation = t["Translation"].ToString();
isEmpty = (bool)t["IsEmpty"];
if (currentLanguageID != languageID)
if (isFirstLanguageElement)
currentLanguageID = languageID;
xw.WriteStartElement("language");
if (app.XmlLanguageElementIdType.ToLower() == "name")
xw.WriteAttributeString("name", languageName);
else if (app.XmlLanguageElementIdType.ToLower() == "code")
xw.WriteAttributeString("code", languageCode);
isFirstLanguageElement = false;
else
xw.WriteEndElement();
xw.WriteStartElement(app.XmlTranslationElementName);
xw.WriteAttributeString("id", resourceCode);
if (isEmpty)
xw.WriteString("");
xw.WriteFullEndElement();
else
xw.WriteString(translation);
counter += 1;
if (counter == translations.Rows.Count)
xw.Close();
Resync method .NET General
method not many Vista mail
Method invocation failed because [System.String] doesn't contain a method PowerShell
Doctype in XmlTextWriter PowerShell
Problem: Can not use <Reboot> or <Win32Shutdown> Method of Win32_OperatingSystem PowerShell
