| | dropdownlist databinding problem I have a radiobuttonlist control which dictate what to display in a dropdown list: <asp:SqlDataSource ID="sqlDataSrouce1" runat="server" ConnectionString="<%$ ConnectionStrings:ConnectionString1 %>" SelectCommand="SELECT * FROM [qry2] "> </asp:SqlDataSource> Protected Sub rdlEventType_SelectedIndexChanged(ByVal sender As Object, ByVal e As System.EventArgs) If rdlEventType.SelectedValue = "abc" Then sqlDataSrouce1.SelectCommand = "SELECT * FROM [qry1]" Else sqlDataSrouce1.SelectCommand = "SELECT * FROM [qry2]" End If dropdown1.DataBind() dropdown1.SelectedIndex = 0 End Sub The radiobuttonlist has one of the non-"abc" buttons checked as the default. Upon entering the form, I select "abc" first. The dropdown displays data from qry1 correctly. Without exiting the form, I switch to a a non-"abc" radiobutton. The dropdown then displays qry2 data fine. Then come the problem: if I switch back to "abc", the dropdown STILL displays qry2 data. So why doesn't the data binding work the third time? I also tested having the SelectCommand setting removed from the SqlDataSource control itself. No luck; the behaviour is still the same. Any insight appreciated. |
| Add Event Handler to dynamic DropDownList?????? | .NET General | |||
| How to copy dropdownlist to each other? | .NET General | |||
| Issue need your help: How to control combox/dropdownlist in web page? | PowerShell | |||
