| | Printing issues with VB PowerPack V3 printer compatibility library I'm redeveloping a VB6 program that prints a lot of labels using ZPL code on a Zebra industrial label printer (uses ZPL for speed) and raw text to a dot matrix tractor feed printer. I have tried using the RawPrinterHelper class from MSDN (http://support.microsoft.com/?kbid=322091) that calls unmanaged API's but I've had a few runtime crashes that have made me look for a managed code equivelant, and could only find the VB powerpack Printer Compatibility Library. I have three problems with this library: 1) It's a lot slower than the RawPrinterHelper Class / VB6 printer object (about 15 times slower) 2) Like the old VB6 printer object, it does something stupid with multiple CRLF's and I need to put in far more CRLF's than I really need to space my tractor feed forms correctly. 3) Every document I print shows a progress dialog - which constantly interupts the user since the printing (hundreds of labels at a time) is done on a background worker thread to keep the UI is fully functional. I really need a managed code way of sending raw data to a printer, but fast, and without progress dialogs. Can anyone help me? |
| Access 2003 compatibility library | Software | |||
| Media Player Library Issues | Vista music pictures video | |||
| HP Printer compatibility issues | Drivers | |||
| General Printing Issues (Default Printer)(Excel)(Outlook) | Vista print fax & scan | |||
| My Music Library Issues with Vista Media Center | Vista music pictures video | |||
