| | SQL connection string encoded in a Uri? I've been looking for an established way to encode a connection string into a Uri. Uri's are used for file access using File://path. Has anyone seen a Sql://server/db/table?query approach? Thanks |
| | Re: SQL connection string encoded in a Uri? Lou wrote: Quote: > I've been looking for an established way to encode a connection string into a > Uri. Uri's are used for file access using File://path. Has anyone seen a > Sql://server/db/table?query approach? > resembles them. For example, a connection string for SQL Server using the jTDS driver looks like this: jdbc:jtds:sqlserver://<server>\<instance>:<port>/<database> The question is, why would you want to do this for .NET connection strings? Those have an established format too, it just doesn't resemble a URI. The general format is just simple key=value pairs, separated by semicolons: Provider=<provider>;<param>=<value>;... There's any number of ways you can stuff this in a URI, but you'll have to roll your own mechanism for encoding and decoding them (the Uri class is only of limited help here). But again, why would you? Is there some place you can store URIs but not general strings? Note that it's a very bad idea to allow arbitrary queries and pass those around as URIs, for reasons I hopefully don't have to elaborate. You may want to look at a REST approach to resources instead, but without tying those to specific database tables. Take a look at ADO.NET Data Services, for example: http://msdn.microsoft.com/data/bb931106 -- J. |
| | Re: SQL connection string encoded in a Uri? Jeroen, Thanks, so I'm not crazy. What I'm after here is a way to store a location for a data source or sink. I want to keep a uniform link for ANY source or sink. Why should there be a way to connect to a web site/FTP/Mail/File etc and not have a way to use that same Uri (emphasis on Universal) without someway of including SQL in the mix? I'm prepared to 'roll my own' on this. It's an internal thing. I suppose since most SQL server access is managed intermurrally having a URI wouldn't provide universal access but I'm looking for consistency of declaration. Otherwise I'd have to check to see if the string was a connection string or a URI. Not so terrible I guess but not quite esthetic. :-) Lou "Jeroen Mostert" wrote: Quote: > Lou wrote: Quote: > > I've been looking for an established way to encode a connection string into a > > Uri. Uri's are used for file access using File://path. Has anyone seen a > > Sql://server/db/table?query approach? > > > resembles them. For example, a connection string for SQL Server using the > jTDS driver looks like this: > > jdbc:jtds:sqlserver://<server>\<instance>:<port>/<database> > > The question is, why would you want to do this for .NET connection strings? > Those have an established format too, it just doesn't resemble a URI. The > general format is just simple key=value pairs, separated by semicolons: > > Provider=<provider>;<param>=<value>;... > > There's any number of ways you can stuff this in a URI, but you'll have to > roll your own mechanism for encoding and decoding them (the Uri class is > only of limited help here). But again, why would you? Is there some place > you can store URIs but not general strings? > > Note that it's a very bad idea to allow arbitrary queries and pass those > around as URIs, for reasons I hopefully don't have to elaborate. You may > want to look at a REST approach to resources instead, but without tying > those to specific database tables. Take a look at ADO.NET Data Services, for > example: http://msdn.microsoft.com/data/bb931106 > > -- > J. > |
| | Re: SQL connection string encoded in a Uri? Lou wrote: Quote: > Actually, you've answered my original question which is whether it's > possible (acceptable) to distort a URI to encode a SQL source/Sink location. > I'm not actually thinking of using it as a 'message' per se. I just want to > be able to handle requests for data sources and sinks uniformly. To give you > a bit of a scenario: in my company, and probably in many, there are > occasionally requests that go out to field people to provide data in some > form. Sometimes it's Excel, sometimes it's in a formatted form etc. This > data is then returned by email and compiled into another spreadsheet (yes, a > fairly primitive thought process.) After a couple of these experiences I > decided to build something that would take a source document like a > spreadsheet, take the column names and types, store them and use it to > recreate a sink in whatever destination is identified by some description. > Uri's seemed to be appropriate but there are some holes, most notably SQL > resources. So, thanks for that. > are meant to uniquely label things, often more specifically by use of a location (the ever popular URLs). What they're not good at is additionally embedding the format of the thing you're labeling, and they're almost never used for that. For example, http://www.microsoft.com describes a resource accessed through the HTTP protocol, but it doesn't tell you anything about HTML -- that's outside the scope. Similarly, an sql:// URI could specify a table in a database on a server, but it's not natural to use it to describe the table's structure as well. So you could use URIs for the sources and destinations of the messages as you describe them, but you would need to lay down the format of those messages quite rigidly, or a way to figure out the format for each URI scheme. If you've only ever got one format that's not so hard, but otherwise you need some good error handling strategies ("whoops, the table's structure doesn't match my spreadsheet, I'll guess I'll just cut a few columns"). Quote: > I can see, however, from the issues you've pointed out that there's probably > a good reason why SQL:// is not 'out there' much as a URI to retrieve SQL > data. It's ironic since SQL data stores are probably where most of the > world's data resides. I'm sure query formatting probably could be devised to > get data, even in arbitrarily complex ways. I wonder why that formatting > hasn't been addressed as since just about everything else has been serialized > in some way and passed through some standard parser to get to the various > flavors of SQL Queries. > already been described: it's ANSI SQL. Squeezing all of it into URI form would be a hell of a job (and you'd end up with some ridiculously big and unreadable URIs). You could turn the URI into a simple "inject any system-specific query here" endpoint, but if you do that there's really no benefit over just exposing a script or application over HTTP to do the same. Recapping: I could see URIs being used to point to a table or view on an arbitrary server, but anything more complicated than that goes against the nature of URIs. -- J. |
| SQL Server connection string for deployment ? | .NET General | |||
| Web.config and Connection String Management | .NET General | |||
| Help with connection string | .NET General | |||
| Re: Inserting LDAP server into connection string?? | VB Script | |||
| ASP connection string to SQL2005 | VB Script | |||
