| | Problem with setting Properties to UserControls Hi, I was trying to set properties to a user control I was writing, name it 'uc1'. I placed uc1 in another user control I'd wrote: 'mainUc'. In uc1 I have set a few WebControls and some public properties (e.g., Double[] _prices; Prices) and initialized them on Page_Load. When the application runs (a web form) it loads 'mainUc' that contains 'uc1'. As long as no post back is being applied uc1.Prices[i] contains the value that was set on Page_Load (not on PostBack), but if i triy to access this property (or any other) I get nothing or exception in case of array. Is there a way to define properties that will still be 'alive' after postback (without using WebControls)? Am I doing something wrong by applying win application techniques to web environment? Thanks, David |
| | RE: Problem with setting Properties to UserControls Hello David, Based on your description, I guess you may write code like the following, In the uc1.ascx.cs, public double[] Prices; protected void Page_Load(object sender, EventArgs e) { if (!IsPostBack) { Prices = new double[4] { 1.1, 2.2, 3.3, 4.4 }; } } In the Default.aspx.cs protected void Button1_Click(object sender, EventArgs e) { foreach (double d in this.mainUc1.uc11.Prices) { Debug.Print (d.ToString()); } } In this case, when the web form starts, the uc1's Page_Load function is called. Since this is first time the page gets loaded, the Prices array's initial codes will be executed. After that, if we click the button on the default page, the child user control gets post back. This time, the initial codes is not executed. Therefore later when we are trying to access the Prices array in the button click event handle, it will throws an exception. To keep the variable still available after the uc1 is post back, we cannot store it in the class property. We need to store it in the ApplicationState collection as described in this MSDN document http://msdn.microsoft.com/en-us/libr...rol.ispostback (VS.71).aspx. The following code works fine in my side, In the uc1.ascx.cs, protected void Page_Load(object sender, EventArgs e) { if (!IsPostBack) { this.Application.Add("Prices",new double[4] { 1.1, 2.2, 3.3, 4.4 }); } } In the Default.aspx.cs protected void Button1_Click(object sender, EventArgs e) { foreach (double d in (double[])this.mainUc1.uc11.Application.Get("Prices")) { Debug.Print (d.ToString()); } } If I have misunderstood your questions, please feel free to let me know. And I will try my best to follow up. Have a nice day! Best regards, Ji Zhou (v-jzho@xxxxxx, remove 'online.') Microsoft Online Community Support Delighting our customers is our #1 priority. We welcome your comments and suggestions about how we can improve the support we provide to you. Please feel free to let my manager know what you think of the level of service provided. You can send feedback directly to my manager at: msdnmg@xxxxxx. ================================================== Get notification to my posts through email? Please refer to http://msdn.microsoft.com/en-us/subs...#notifications. Note: The MSDN Managed Newsgroup support offering is for non-urgent issues where an initial response from the community or a Microsoft Support Engineer within 1 business day is acceptable. Please note that each follow up response may take approximately 2 business days as the support professional working with you may need further investigation to reach the most efficient resolution. The offering is not appropriate for situations that require urgent, real-time or phone-based interactions or complex project analysis and dump analysis issues. Issues of this nature are best handled working with a dedicated Microsoft Support Engineer by contacting Microsoft Customer Support Services (CSS) at http://support.microsoft.com/select/...tance&ln=en-us. ================================================== This posting is provided "AS IS" with no warranties, and confers no rights. |
| | Re: Problem with setting Properties to UserControls Hi Ji, It looks like a solution for my problem. I'll study it and let you know. Thank you so much, David """Ji Zhou [MSFT]""" <v-jzho@xxxxxx> wrote in message news:fraeyUhVJHA.3380@xxxxxx Quote: > Hello David, > > Based on your description, I guess you may write code like the following, > > In the uc1.ascx.cs, > public double[] Prices; > > protected void Page_Load(object sender, EventArgs e) > { > if (!IsPostBack) > { > Prices = new double[4] { 1.1, 2.2, 3.3, 4.4 }; > } > } > > In the Default.aspx.cs > protected void Button1_Click(object sender, EventArgs e) > { > foreach (double d in this.mainUc1.uc11.Prices) > { > Debug.Print (d.ToString()); > } > } > > In this case, when the web form starts, the uc1's Page_Load function is > called. Since this is first time the page gets loaded, the Prices array's > initial codes will be executed. After that, if we click the button on the > default page, the child user control gets post back. This time, the > initial > codes is not executed. Therefore later when we are trying to access the > Prices array in the button click event handle, it will throws an > exception. > > To keep the variable still available after the uc1 is post back, we cannot > store it in the class property. We need to store it in the > ApplicationState > collection as described in this MSDN document > http://msdn.microsoft.com/en-us/libr...rol.ispostback > (VS.71).aspx. > > The following code works fine in my side, > > In the uc1.ascx.cs, > protected void Page_Load(object sender, EventArgs e) > { > if (!IsPostBack) > { > this.Application.Add("Prices",new double[4] { 1.1, 2.2, > 3.3, 4.4 }); > } > } > > In the Default.aspx.cs > protected void Button1_Click(object sender, EventArgs e) > { > foreach (double d in > (double[])this.mainUc1.uc11.Application.Get("Prices")) > { > Debug.Print (d.ToString()); > } > } > > If I have misunderstood your questions, please feel free to let me know. > And I will try my best to follow up. Have a nice day! > > Best regards, > Ji Zhou (v-jzho@xxxxxx, remove 'online.') > Microsoft Online Community Support > > Delighting our customers is our #1 priority. We welcome your comments and > suggestions about how we can improve the support we provide to you. Please > feel free to let my manager know what you think of the level of service > provided. You can send feedback directly to my manager at: > msdnmg@xxxxxx. > > ================================================== > Get notification to my posts through email? Please refer to > http://msdn.microsoft.com/en-us/subs...#notifications. > > Note: The MSDN Managed Newsgroup support offering is for non-urgent issues > where an initial response from the community or a Microsoft Support > Engineer within 1 business day is acceptable. Please note that each follow > up response may take approximately 2 business days as the support > professional working with you may need further investigation to reach the > most efficient resolution. The offering is not appropriate for situations > that require urgent, real-time or phone-based interactions or complex > project analysis and dump analysis issues. Issues of this nature are best > handled working with a dedicated Microsoft Support Engineer by contacting > Microsoft Customer Support Services (CSS) at > http://support.microsoft.com/select/...tance&ln=en-us. > ================================================== > This posting is provided "AS IS" with no warranties, and confers no > rights. > |
| Setting COM Port Properties, Named pipe | VB Script | |||
| Setting object properties | PowerShell | |||
| Error 0x88982f50 Setting JPG File Properties | Vista file management | |||
| setting up standard user with admin-like properties | Vista account administration | |||
