| | Direct Binding-Schema validation at receive location Hi, I have a application which is based on schema A.it has a receive location where i use XmlTransmit pipeline to do schema validation with schema A. I have similar 2 more applications which are based on schema B,C(which differ a little bit with schema A,ex:targetnamespace is different & other data).these applications has their own receive location where i use XmlTransmit pipeline to do schema validation. all the applications use file adapter for input transmission of xml file. Now as per client reqirement instead of having different folder for receiveing xml file to each application.I need to make common folder for all applications. so for this i created one more application(by name MAIN) which will receive all the xml files at one folder(Ex C:\Common). and i am reading the TargetNamespace by using BTS.MesageType based on that value i am passing that xml file to send port (3 different send ports) which are directly coupled(using direct binding -filter expression as BTS.messageType=""and BTS.receivePortName="") to receive location of each application. Now the issue is when I am using direct binding with receive location there are no settings at receive location for specifying xmlTransmit pipeline so that it will do the schema validation with the schema. i can not use custom c# schema validation component as it leads to change in the flow of orchestration what i already have.. so how can i do use xmltransmit at receive location while using directbinding...? Thanks in advance Naresh |
| Sending of files direct from their location | Vista mail | |||
| sending files pictures direct from location | Vista mail | |||
