Vista - Radio buttons do not save state after post back
Old 12-05-2008   #1 (permalink)
Goldenrate
I placed a set of RadioButtonList control on a one of the steps of a Wizard.
Here is how I defined it:
<asp:WizardStep runat="server" Title="My Title" >
<asp:RadioButtonList ID="rblIsSpouseReg" runat="server"
OnSelectedIndexChanged="rblIsSpouseReg_SelectedIndexChanged"
RepeatDirection="Horizontal" AutoPostBack="True" >
<asp:ListItem Text="No" Value="No"></asp:ListItem>
<asp:ListItem Text="Yes" Value="No"></asp:ListItem>
</asp:RadioButtonList>
</asp:WizardStep>
As you see I haven't set any default value for 'Selected', yet if I select
'Yes' and initiate a postback in response, the radio button is automatically
being set to 'No'.
Any ideas?
Thanks,
David
Old 12-06-2008   #2 (permalink)
Vista Business x64
Re: Radio buttons do not save state after post back
I notice that the "Value" for both Yes and No listitems is "No." Is that a typo from entering you code here on the forum or is that cut-and-pasted from your code?
Save State Virtual PC
Grouping radio buttons w/o group box .NET General
How to create a dialog box with radio buttons VB Script
Using Radio Buttons within Powershell PowerShell
Application won't save last state Vista security
