Vista - Great difficulty w/wireless card
Old 12-14-2008   #1 (permalink)
awawego
have an older Dell lap - cannot get my linksys wireless card to work - put in
new harddrive and installed win xp home - this same card works well in
another identical dell - power light comes on but not the "link" light. For
some reason they seem to be not communicating. Any guidance would help.
Old 12-14-2008   #2 (permalink)
PvdG42
Re: Great difficulty w/wireless card
"awawego" <awawego@xxxxxx> wrote in message
news:03A7DD39-D963-4920-8313-5405D7933AD6@xxxxxx
> in
> For
As this is a .NET programming discussion group, I'd suggest posting in an
applicable Windows XP group for a better response. Here's how to find one.
As you appear to be using a web interface, start here to find an appropriate
group:
http://www.microsoft.com/communities...s/default.aspx
Click the + beside your language. then scroll down to Windows. In Windows,
open the category for Windows XP, then find a group there to
post in.
Dell Wireless WLAN Card Wireless Network Controller has stopped working Network & Sharing
Vista Supported Wireless USB Adapter / Wireless PCI Card Vista General
Wireless Card Driver(Wireless not working) Network & Sharing
wireless - great signal cannot connect Vista General
Wireless Card Vista General
