Vista - Custom TraceListener using custom LogEntry
Old 12-17-2008   #1 (permalink)
cleanwire
I'm using Exception Block which sends message to logging handler. I've
created a custom TraceListener that expects a custom log entry. I'd
like to say...
public override void TraceData(TraceEventCache eventCache, string
source, TraceEventType eventType, int id, object data)
if (data is MyCustomEntry) ...
How do I create a MyCustomEntry with the exception data, and how do I
pass it to TraceData? Thanks
Custom emoticons showing in Groups although disabled custom emoticons Live Messenger
Accessing custom types output from custom cmdlet's in C# GUI PowerShell
types.custom.ps1xml for custom members PowerShell
custom dictionary Vista mail
