Vista - should i use control panel or mmc?
Old 12-19-2008   #1 (permalink)
JasonS
Hi
What is the recommended user interface for letting users configure
applications?
Is it using a control panel applet, MMC or something else.
Thanks
Jason
Old 12-19-2008   #2 (permalink)
Family Tree Mike
RE: should i use control panel or mmc?
"JasonS" wrote:
Quote:
> Hi
> applications?
> Thanks
> Jason
If you are configuring a service, then either of those may be fine. When
you say applications though, I tend to think of users being used to seeing a
"Tools" menu item, with a choice of "Options" to configure such things.
Mike
Old 12-24-2008   #3 (permalink)
Josh Einstein
Re: should i use control panel or mmc?
I second that. If you're talking about an app with a UI, don't make the
iPhone mistake where you gotta go to the control panel just to change stupid
things like sort order settings.
"Family Tree Mike" <FamilyTreeMike@xxxxxx> wrote in
message news:A9A84AC5-407B-41D1-8832-B5E1659D4169@xxxxxx
Quote:
> "JasonS" wrote:
Quote:
>> Hi
>> applications?
>> Thanks
>> Jason
> a
> Mike
Control Panel General Discussion
How can I control the size of icons in Control Panel? Vista General
Control panel Vista General
Lost Control of Control Panel Vista General
control panel Vista General
