| | CD-ROM drive not recognizing cd is there With an XP system, my CD drive doesn't acknowledge there's a CD in there when there is. Driver status says it's working, I've tried uninstalling, re-installing, no luck. Any ideas? -- jgraf |
| | RE: CD-ROM drive not recognizing cd is there "jgraf" wrote: Quote: > With an XP system, my CD drive doesn't acknowledge there's a CD in there when > there is. Driver status says it's working, I've tried uninstalling, > re-installing, no luck. > Any ideas? > -- > jgraf then sits there. The green light blinks a couple times, but when I go to My computer and look at the drive, it's empty. I can eject the disk from the computer screen, so that responds, but nothing else. Did you fix it? What did you do?? |
| System not recognizing cd is in drive | Drivers | |||
| Vista is not recognizing hard drive | Drivers | |||
| CD drive not recognizing disks | Vista hardware & devices | |||
| Vista64 not recognizing SATA Drive | Vista hardware & devices | |||
| DVD drive not recognizing that a DVD-ROM is inserted | Vista hardware & devices | |||
