Vista - SQL update problem
Old 01-03-2009   #1 (permalink)
Patrick D.
SQL update problem
C#, webapplication
Hi
usually this sql update command works fine:
(html is a memo-field)
UPDATE [Table1] SET [html]='content of a memo-field' WHERE [ContentID]='1'
As soon as I have a content like
'winter' is colder than "summer"
to assign to the html-field the sql-statement produces an error since the
little signs around winter and summer are a problem for the sql-statement.
Server.HtmlEncode(String) didn't help.
What do I need to do, to be able to assign any text-contents to the
memo-field?
Thanks for your help.
Patrick
Old 01-03-2009   #2 (permalink)
Göran Andersson
Re: SQL update problem
Patrick D. wrote:
Quote:
> C#, webapplication
> Hi
> memo-field?
> Patrick
The preferrable way to handle this is to use a parameterised query. Then
you don't have to worry about encoding the string.
UPDATE [Table1] SET [html]=? WHERE [ContentID]='1'
Add a parameter to the command object. Example:
cmd.Parameters.Add("", OleDbType.VarChar, 0).Value = "'winter' is colder
than \"summer\"";
If you can't use parameters, you have to encode the string when you put
it in the query. This is done differently depending on what database you
are using. Here are some of the most common:
SQL Server: replace ' with ''
MS Access: replace ' with ''
MySQL: replace \ with \\, then replace ' with \'
Göran Andersson
_____
http://www.guffa.com
HP UPDATE FIRMWARE update problem? Drivers
Update Problem Vista performance & maintenance
Comodo Firewall update addresses Windows Update problem Vista security
Comodo Firewall update addresses Windows Update problem Vista General
Huge problem with security update kb935902 on Windows Update Vista General
