Vista - a disk read error has occured press CTRL ALT & DEL TO RESTART
Old 01-06-2009   #1 (permalink)
Dave M
i get the Constatnt above error at random times with my windows xp
professional (intergrated sp2) when i Boot up at first i thought it may have
been my 1st Drive seagate 500gb SATA 2 had less or just over 6 months so i
took it out (in process of returning for diagnostic testing) got another
drive Brand New but a maxtor 250GB in hope for more reliability re installed
windows on that and by a shock it did it again on a brand new drive ime
thinking there may be a million to one chance it couldnt happen
when it lets me get into windows it runs as sweet as a nut
i have tried the following
.. change the SATA cable
.. move the SATA cable to another SATA port
.. move the drive to another drive bay
.. Update Chipset Drivers
.. Bios is up to date
Spec
INTEL QUAD CORE 12MB cache (not overclocked)
ASUS P5NT - DELUXE MOTHERBOARD
2GB CRUTIAL BALLISTIX 6400
ASUS 8800GTX GRAPHICS PCI - EXPRESS
MAXTOR 250GB DIAMOND MAX 21 SATA 2 HD
AMPLE COOLING 6 FANS AND A NVIDIA ZALMAN COOLER
i bet if i formatted Windows Again it would do the same thing
i tried the Help n Support Database nothiing even close
Any Solutions
a disk read error occured press ctrl alt delete General Discussion
Disk Read Error Press Ctrl, Alt, Del To Restart Vista installation & setup
Disk Read Error: Press Ctrl Alt Del to Restart Vista hardware & devices
A disk read error has occurred; press Ctrl-Alt-Del to restart Vista hardware & devices
A Disk Read Error Occurred Press Ctrl-Alt-Del to Reboot Vista installation & setup
