| Guest | Problem with circular references Hi newsgroup I have a little problem in designing my assemblies. Following situation: 1. I have 3 Assemblies: Assembly_A, Assembly_B and Assembly_C 2. Assembly_A has a Collection of Assembly_C 3. Assembly_B has as Collection of Assembly_C 4. Assembly_C has a Object of Assembly_A and another one of Assembly_B So that's the situation and the situation must be like this (relationally) because Assembly_A and Assembly_B represent contractors and Assembly_C represents the contract. A contract is made between A and B. Both contractors can have n contracts. A contract has one A and one B. When trying to build this solution with team build the build process stops in case of circular references. It is logical, because A cannot be build until C is build and C cannot be build until A is build. Now my question. Is there a desing that don't destry the logic of the depencies between the assemblies but don't result in build errors. If not, what kind of design should I use for cases like this? Thanks for every suggestions and help! Best regards D.H. Lee |
| Guest | Re: Problem with circular references If possible, commonly used objects should be pushed into common assemblies. So if what C uses in A doesn't have to be in A but could be in MyCommonStuff.dll (that knows nothing about A, B or C) then so much the better. Look seriously at whether or not you can achieve this. But if that's not possible then a couple of general comments : 1) use interfaces. If A needs B and B needs C and C needs A, then change it so that C knows absolutely nothing about A but uses an interface (defined in MyCommonStuff.dll) that A supports. 2) dynamic loading and object creation You can write C so that at run time it gets passed a few strings that tell it you need type "MyNameSpace.MyType" and its in assembly "MyDll_C.dll" The type supports an interface that C knows about and hey presto it works. A circular reference definitely means your design needs changing. HTH, Adam. "don H. Lee" <nospam@xxxxxx> wrote in message news:O5TTJ3icJHA.1532@xxxxxx Quote: > Hi newsgroup > > I have a little problem in designing my assemblies. > > Following situation: > > 1. I have 3 Assemblies: Assembly_A, Assembly_B and Assembly_C > 2. Assembly_A has a Collection of Assembly_C > 3. Assembly_B has as Collection of Assembly_C > 4. Assembly_C has a Object of Assembly_A and another one of Assembly_B > > So that's the situation and the situation must be like this (relationally) > because Assembly_A and Assembly_B represent contractors and Assembly_C > represents the contract. A contract is made between A and B. > > Both contractors can have n contracts. A contract has one A and one B. > > When trying to build this solution with team build the build process stops > in case of circular references. > It is logical, because A cannot be build until C is build and C cannot be > build until A is build. > > Now my question. Is there a desing that don't destry the logic of the > depencies between the assemblies but don't result in build errors. > > If not, what kind of design should I use for cases like this? > > Thanks for every suggestions and help! > > Best regards > > D.H. Lee > |
| Guest | Re: Problem with circular references On Fri, 9 Jan 2009 08:40:03 +0100, "don H. Lee" <nospam@xxxxxx> wrote: Quote: >Hi newsgroup > >I have a little problem in designing my assemblies. > >Following situation: > >1. I have 3 Assemblies: Assembly_A, Assembly_B and Assembly_C >2. Assembly_A has a Collection of Assembly_C >3. Assembly_B has as Collection of Assembly_C >4. Assembly_C has a Object of Assembly_A and another one of Assembly_B > >So that's the situation and the situation must be like this (relationally) >because Assembly_A and Assembly_B represent contractors and Assembly_C >represents the contract. A contract is made between A and B. > >Both contractors can have n contracts. A contract has one A and one B. > >When trying to build this solution with team build the build process stops >in case of circular references. >It is logical, because A cannot be build until C is build and C cannot be >build until A is build. > >Now my question. Is there a desing that don't destry the logic of the >depencies between the assemblies but don't result in build errors. > >If not, what kind of design should I use for cases like this? > >Thanks for every suggestions and help! > >Best regards > >D.H. Lee A and B would implement that Interface, which would be defined in a fourth assembly that does not reference any of the others. |
| Project References. | .NET General | |||
| references an object name with a variable | PowerShell | |||
| Best references for learning C# for PowerShell? | PowerShell | |||
