Vista - Internal clock problem
Old 01-12-2009   #1 (permalink)
Help with internal clock issue
The internal clock in the computer has lost its mind. It either gains or
loses time randomly. I have used the sync feature but it hasn't helped.
Specifically when I play on the POGO game site in a timed game I get an error
message that says" do not adjust your time" (and I haven't touched the
clock). When I glance at the clock the time had gained or lost at least 10
min.
Can the internal clock be disabled and if not how do I fix it. Any help
with this is greatly appreciated..
Old 01-13-2009   #2 (permalink)
geekyguy
Re: Internal clock problem
bad battery?
"Help with internal clock issue" <Help with internal clock
issue@xxxxxx> wrote in message
news859CAAB-0526-4669-9D67-0AAAE00BD8B5@xxxxxx
> error
> 10
> min.
Old 01-14-2009   #3 (permalink)
PvdG42
> error
> 10
> min.
Following Geekboy, Does your clock lose time if you shut the system down
(remove all power) for a period of time? If so, you probably need to replace
the CMOS battery. The symptoms you describe, however, don't sound like the
battery. Have you tweaked your BIOS? If so, what happens if you reset to
defaults?
If these suggestions don't help, try posting in a Windows group, rather
than in this .NET programming group. Here's how to find the group you need.
As you appear to be using a web interface, start here to find an appropriate
group:
http://www.microsoft.com/communities...s/default.aspx
Click the + beside your language. then scroll down to Windows. In Windows,
open the category for your version of Windows. Find a group there to post
in.
5 min clock problem with Vista/Acer General Discussion
Problem with Internal Microphone (it isn't working) Sound & Audio
Windows Live mail internal clock Live Mail
Clock Interrupt Problem Vista General
Internal clock set to UTC time Vista General
