| | Logging Application Block - Modify settings in code? I'm trying to use the Logging Application Block system in the MS Enterprise Library. All my settings are defined in the config file and everything is working fine. However, there is one setting that needs to be dynamic dependent on the environment where the application is currently running I have added a listener, and I need to be able to modify the "url" paramater of that listener in code. Can this be done? Thanks, Kim |
| Modify Built-in Cmdlet Code | PowerShell | |||
| question on logging block | .NET General | |||
| Getting Custom Source Name Using Enterprise Library Logging Block | .NET General | |||
| Re: Cant modify sleep settings | Vista General | |||
