| | Solution Builds Very Very Slow. Hi everybody: I working with a 42 projects solution, 1 is a Windows Forms Project (Main Project) and 41 are Windows Libraries (dll). 37 of 42 Dll projects are unloaded from the solution and are referenced as Asemblies in GAC. The other 5 projects are still loaded in solution and are referenced as Project References. The solution is Code Version Controlled using Visual Source Safe. The thing is that the Build time is taking about five to seven minutes. That is a lot of time. Context information. Visual Basic .Net 2008 SQL Server 2005 Net Framework 3.5 PCs. Pentium 4 HT 2 GB RAM Please, I will appreciate any help. Best regards. Sergio Montero |
| | Re: Solution Builds Very Very Slow. Icarus wrote: Quote: > Hi everybody: > > I working with a 42 projects solution, 1 is a Windows Forms Project (Main > Project) and 41 are Windows Libraries (dll). > > 37 of 42 Dll projects are unloaded from the solution and are referenced as > Asemblies in GAC. The other 5 projects are still loaded in solution and are > referenced as Project References. Quote: > The solution is Code Version Controlled using Visual Source Safe. Quote: > The thing is that the Build time is taking about five to seven minutes. That > is a lot of time. > > Context information. > Visual Basic .Net 2008 > SQL Server 2005 > Net Framework 3.5 > > PCs. > Pentium 4 HT > 2 GB RAM > > > Please, I will appreciate any help. Watch the output window when you compile, to see which of the projects that take time to compile. -- Göran Andersson _____ http://www.guffa.com |
| | Re: Solution Builds Very Very Slow. The main project is the one that is consuming all that time. This is the output: Best regards. ------ Build started: Project: SADER, Configuration: Debug Any CPU ------ C:\Archivos de programa\Microsoft SDKs\Windows\v6.0A\bin\LC.exe /target:SADER.exe /complist:"My Project\licenses.licx" /outdir bj\Debug\/i:"C:\Archivos de programa\ComponentOne Studio.NET 2.0\bin\C1.Win.C1Sizer.2.dll" /i:"C:\Archivos de programa\Developer Express ..NET v8.2\Sources\DevExpress.DLL\DevExpress.Data.v8.2.dll" /i:"C:\Archivos de programa\Developer Express .NET v8.2\Sources\DevExpress.DLL\DevExpress.Utils.v8.2.dll" /i:"C:\Archivos de programa\Developer Express .NET v8.2\Sources\DevExpress.DLL\DevExpress.XtraEditors.v8.2.dll" /i:"C:\Archivos de programa\Developer Express .NET v8.2\Sources\DevExpress.DLL\DevExpress.XtraNavBar.v8.2.dll" /i:"C:\Archivos de programa\Reference Assemblies\Microsoft\Framework\v3.5\System.Core.dll" /i:"C:\Archivos de programa\Reference Assemblies\Microsoft\Framework\v3.5\System.Data.DataSetExtensions.dll" /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Data.dll /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Deployment.dll /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Design.dll /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.dll /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Drawing.dll /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.EnterpriseServices.dll /i:"C:\Archivos de programa\Reference Assemblies\Microsoft\Framework\v3.0\System.Runtime.Serialization.dll" /i:"C:\Archivos de programa\Reference Assemblies\Microsoft\Framework\v3.0\System.ServiceModel.dll" /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Web.Services.dll /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Windows.Forms.dll /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Xml.dll /i:"C:\Archivos de programa\Reference Assemblies\Microsoft\Framework\v3.5\System.Xml.Linq.dll" /i:T:\Otros\....dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Aspirantes.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Carreras.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.CiclosEscolares.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Clientes.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.DiasInhabiles.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Divisiones.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Documentos.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.EscuelasDeProcedencia.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Estados.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Localidades.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.MotivosDeBaja.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Municipios.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.NivelesAcademicos.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Paises.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.PeriodosEscolares.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Procesos.dll /i:T:\Otros\VSS\UTMFrameworkDlls\UTM.Sade.Catalogos.ProcesosDeAdmision.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Productos.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.RangosEdad.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.TiposDeBaja.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.TiposDeIngresoAcademico.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.TiposDeIngresoFinanciero.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Titulos.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Common.dll /i:C:\SADE-R\REFERENCIAS\HERRAMIENTAS\UTM.Sade.Herramientas.Opciones\bin\Debug\UTM.Sade.Herramientas.Opciones.dll /i:C:\SADE-R\REFERENCIAS\INGRESO\RESULTADOS_CENEVAL\UTM.Sade.Ingreso.Ceneval.Puntajes\bin\Debug\UTM.Sade.Ingreso.Ceneval.Puntajes.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Procesos.Bajas.BajaManual.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Procesos.Facturacion.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Procesos.ReactivacionAlumnos.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Procesos.RegistroAspirantes.dll /i:C:\SADE-R\REFERENCIAS\REPORTES\PROCESOS\UTM.Reportes.Procesos.Admision\bin\Debug\UTM.Sade.Reportes.Procesos.Admision.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Reportes.Procesos.Bajas.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Reportes.Procesos.Facturacion.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Reportes.Procesos.Registro.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Reportes.Seguridad.dll /i:T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Reportes.Visor.dll /i:T:\Otros\VSS\UTMFrameworkDlls\UTM.Security.Api.dll /i:T:\Otros\VSS\UTMFrameworkDlls\UTM.Winforms.ActionButtons.dll /i:T:\Otros\VSS\UTMFrameworkDlls\UTM.Data.Validation.dll /i:T:\Otros\VSS\UTMFrameworkDlls\UTM.Net.Mail.dll /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.VisualC.dll /i:"C:\Archivos de programa\Component Factory Pty Ltd\Krypton Toolkit 3.0.0\Bin\ComponentFactory.Krypton.Toolkit.dll" /i:"C:\Archivos de programa\ComponentOne Studio.NET 2.0\bin\C1.Win.C1Command.2.dll" /i:"C:\Archivos de programa\Business Objects\Common\2.8\managed\CrystalDecisions.ReportSource.dll" /i:T:\Otros\VSS\UTMFrameworkDlls\UTM.Security.PasswordGenerator.dll /i:"C:\Archivos de programa\Business Objects\Common\2.8\managed\CrystalDecisions.Windows.Forms.dll" /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.VisualBasic.dll /i:"C:\Archivos de programa\ComponentOne Studio.NET 2.0\bin\C1.Win.C1List.2.dll" /i:"C:\Archivos de programa\ComponentOne Studio.NET 2.0\bin\C1.Win.C1Chart.2.dll" /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.DirectoryServices.dll /i:T:\Otros\VSS\UTMFrameworkDlls\UTM.Common.Attributes.dll /i:"C:\Archivos de programa\Business Objects\Common\2.8\managed\CrystalDecisions.Shared.dll" /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Drawing.Design.dll /i:"C:\Archivos de programa\Pegasus Imaging\CapturePRO\V3.0\Components\DotNet\PegasusImaging.WinForms.CapturePro3.dll" /i:"C:\Archivos de programa\ComponentOne Studio.NET 2.0\bin\C1.Win.C1TrueDBGrid.2.dll" /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Transactions.dll /i:c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Configuration.dll /i:T:\Otros\VSS\UTMFrameworkDlls\UTM.Data.Access.dll /i:T:\Otros\VSS\UTMFrameworkDlls\UTM.Winforms.Search.dll /i:T:\Otros\VSS\UTMFrameworkDlls\UTM.Common.Validators.dll /i:T:\Otros\VSS\UTMFrameworkDlls\UTM.Security.ActiveDirectory.dll /i:T:\Otros\VSS\UTMFrameworkDlls\UTM.Security.Encryption.dll /i:"C:\Archivos de programa\Business Objects\Common\2.8\managed\CrystalDecisions.CrystalReports.Engine.dll" c:\WINDOWS\Microsoft.NET\Framework\v3.5\Vbc.exe /noconfig /imports:Microsoft.VisualBasic,System,System.Collections,System.Collections.Generic,System.Data,System.Drawing,System.Diagnostics,System.Windows.Forms,System.Linq,System.Xml.Linq /optioncompare:Binary /optionexplicit+ /optionstrict:custom /nowarn:42016,41999,42017,42018,42019,42032,42036,42020,42021,42022 /optioninfer+ /rootnamespace:SADER /doc bj\Debug\SADER.xml/define:"CONFIG=\"Debug\",DEBUG=-1,TRACE=-1,_MyType=\"WindowsFormsWithCustomSubMain\",PLATFORM=\"AnyCPU\"" /reference:"C:\Archivos de programa\ComponentOne Studio.NET 2.0\bin\C1.Win.C1Sizer.2.dll","C:\Archivos de programa\Developer Express ..NET v8.2\Sources\DevExpress.DLL\DevExpress.Data.v8.2.dll","C:\Archivos de programa\Developer Express .NET v8.2\Sources\DevExpress.DLL\DevExpress.Utils.v8.2.dll","C:\Archivos de programa\Developer Express .NET v8.2\Sources\DevExpress.DLL\DevExpress.XtraEditors.v8.2.dll","C:\Archivos de programa\Developer Express .NET v8.2\Sources\DevExpress.DLL\DevExpress.XtraNavBar.v8.2.dll","C:\Archivos de programa\Reference Assemblies\Microsoft\Framework\v3.5\System.Core.dll","C:\Archivos de programa\Reference Assemblies\Microsoft\Framework\v3.5\System.Data.DataSetExtensions.dll",c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Data.dll,c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Deployment.dll,c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Design.dll,c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.dll,c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Drawing.dll,c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.EnterpriseServices.dll,"C:\Archivos de programa\Reference Assemblies\Microsoft\Framework\v3.0\System.Runtime.Serialization.dll","C:\Archivos de programa\Reference Assemblies\Microsoft\Framework\v3.0\System.ServiceModel.dll",c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Web.Services.dll,c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Windows.Forms.dll,c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Xml.dll,"C:\Archivos de programa\Reference Assemblies\Microsoft\Framework\v3.5\System.Xml.Linq.dll",T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Asignaturas.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Aspirantes.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Carreras.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.CiclosEscolares.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Clientes.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.DiasInhabiles.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Divisiones.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Documentos.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.EscuelasDeProcedencia.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Estados.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Localidades.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.MotivosDeBaja.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Municipios.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.NivelesAcademicos.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Paises.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.PeriodosEscolares.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Procesos.dll,T:\Otros\VSS\UTMFrameworkDlls\UTM.Sade.Catalogos.ProcesosDeAdmision.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Productos.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.RangosEdad.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.TiposDeBaja.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.TiposDeIngresoAcademico.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.TiposDeIngresoFinanciero.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Catalogos.Titulos.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Common.dll,C:\SADE-R\REFERENCIAS\HERRAMIENTAS\UTM.Sade.Herramientas.Opciones\bin\Debug\UTM.Sade.Herramientas.Opciones.dll,C:\SADE-R\REFERENCIAS\INGRESO\RESULTADOS_CENEVAL\UTM.Sade.Ingreso.Ceneval.Puntajes\bin\Debug\UTM.Sade.Ingreso.Ceneval.Puntajes.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Procesos.Bajas.BajaManual.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Procesos.Facturacion.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Procesos.ReactivacionAlumnos.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Procesos.RegistroAspirantes.dll,C:\SADE-R\REFERENCIAS\REPORTES\PROCESOS\UTM.Reportes.Procesos.Admision\bin\Debug\UTM.Sade.Reportes.Procesos.Admision.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Reportes.Procesos.Bajas.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Reportes.Procesos.Facturacion.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Reportes.Procesos.Registro.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Reportes.Seguridad.dll,T:\Otros\VSS\UTMSadeDlls\UTM.Sade.Reportes.Visor.dll,T:\Otros\VSS\UTMFrameworkDlls\UTM.Security.Api.dll,T:\Otros\VSS\UTMFrameworkDlls\UTM.Winforms.ActionButtons.dll /debug+ /debug:Full /filealign:512 /nowin32manifest /out bj\Debug\SADER.exe/resource bj\Debug\SADER.frmSade_Apply.resources/resource bj\Debug\SADER.frmSade_Config.resources/resource bj\Debug\SADER.frmSade_Main.resources/resource bj\Debug\SADER.frmSade_Splash.resources/resource bj\Debug\SADER.Resources.resources/resource bj\Debug\SADER.exe.licenses /target:winexeFormularios\Inicio\frmSade_Apply.Designer.vb Formularios\Inicio\frmSade_Apply.vb Formularios\Inicio\frmSade_Config.Designer.vb Formularios\Inicio\frmSade_Config.vb Formularios\Inicio\frmSade_Main.Designer.vb Formularios\Inicio\frmSade_Main.vb Formularios\Inicio\frmSade_Splash.Designer.vb Formularios\Inicio\frmSade_Splash.vb Modulos\modSade_Declaraciones.vb Modulos\modSade_Main.vb "My Project\AssemblyInfo.vb" "My Project\Application.Designer.vb" "My Project\Resources.Designer.vb" "My Project\Settings.Designer.vb" "Web References\SadeWS\Reference.vb" SADER -> C:\SADE-R\MainProj\SADER\bin\Debug\SADER.exe Done building project "SADER.vbproj". "Göran Andersson" <guffa@xxxxxx> escribió en el mensaje news:eBvGxk6dJHA.5540@xxxxxx Quote: > Icarus wrote: Quote: >> Hi everybody: >> >> I working with a 42 projects solution, 1 is a Windows Forms Project (Main >> Project) and 41 are Windows Libraries (dll). >> >> 37 of 42 Dll projects are unloaded from the solution and are referenced >> as Asemblies in GAC. The other 5 projects are still loaded in solution >> and are referenced as Project References. > So what you really have is a solution with five projects. That's not at > lot. > Quote: >> The solution is Code Version Controlled using Visual Source Safe. > That doesn't affect the compile time. > Quote: >> The thing is that the Build time is taking about five to seven minutes. >> That is a lot of time. >> >> Context information. >> Visual Basic .Net 2008 >> SQL Server 2005 >> Net Framework 3.5 >> >> PCs. >> Pentium 4 HT >> 2 GB RAM >> >> >> Please, I will appreciate any help. > Yes, that's a lot of time. Five to seven seconds would be more typical... > > Watch the output window when you compile, to see which of the projects > that take time to compile. > > -- > Göran Andersson > _____ > http://www.guffa.com |
| Slow start solution | Vista General | |||
| Solution for slow file copying? | Vista General | |||
| Solution found for slow Vista | Vista performance & maintenance | |||
| Found a solution for slow lan detection in Vista | Vista networking & sharing | |||
| American Red Cross Builds Disaster Response Solution with Microsoft Expertise | Vista News | |||
