| | philips sound agent 2 HI ihave installed philips sound agent 2 on xp pro 64 bit edition, when i open sound agent i get error massage ,QVE bus driver is not detected. reinstall the Qsound virtual audio divies bus enumerator driver, cannot find the driver. can anyone help. thanks -- amarjit |
| | Re: philips sound agent 2 Probably not in a .NET programming discussion group, but you can find an appropriate Windows group this way. As you appear to be using a web interface, start here: http://www.microsoft.com/communities...s/default.aspx In the tree on the left, first open the English category, then open Windows. In Windows, find and open the category for your version of Windows. There, you'll find a hardware group to post your question. "bhangra" <myhome@xxxxxx> wrote in message news:9D9A5AFD-A596-4BED-8798-AB3DDEDD40AA@xxxxxx Quote: > HI ihave installed philips sound agent 2 on xp pro 64 bit edition, when i > open sound agent i get error massage ,QVE bus driver is not detected. > reinstall the Qsound virtual audio divies bus enumerator driver, cannot > find > the driver. can anyone help. thanks > -- > amarjit |
| Need uacbflt.sys for Win 7 64-Bit (Philips USB Sound System) | Sound & Audio | |||
| Conexant and Philips. | Vista installation & setup | |||
| Philips DVD | Vista hardware & devices | |||
| Philips Webcam | Vista installation & setup | |||
| PHILIPS DVD+-RW DVD8631 | Vista hardware & devices | |||
