Vista - ObjectDataSource - UpdateParameters is not configured
Old 01-20-2009   #1 (permalink)
bladethinker
We've bound an ObjectDataSource to a class whose "select" returns a
custom object. We point the "update" to a method which accepts the
same kind of object as an input parameter. But after configuring the
ObjectDataSource, the UpdateParameters is not generated. Why isn't
the ObjectDatasource's "update" parameters configured? Thanks
Marty
Old 01-22-2009   #2 (permalink)
Cor Ligthert[MVP]
Re: ObjectDataSource - UpdateParameters is not configured
Marty,
Most probably because you did it wrong, however what was the reason, we
cannot see.
Take the AdoNet newsgroup for this question, there you have more change on
an answer.
Cor
<bladethinker@xxxxxx> wrote in message
news:565068d9-1036-437a-80c5-20e9a5258e5e@xxxxxx
> Marty
Disable sorting on ListView, ObjectDataSource or database ? .NET General
Virtual NIC not configured Virtual PC
Just configured, but won't send/receive Vista mail
ObjectDataSource returns from cache even if select param is differ .NET General
How do I get my email configured correctly? Vista mail
