Vista - Defrag will not work
Old 01-21-2009   #1 (permalink)
Haylesfrend
I tried to defrag my PC after it had come back from repair shop and I got
this message:
MMC cannot open the file C:\WINDOWS\system32\dfrg.msc
This may be because the file does not exist, is not an MMC console, or
was created by a later version of MMC. and so on about access rights.
I have emailed the repair shop and am waiting for a reply but also wonder if
the combined knowledge here can suggest anything
Haylesfrend
Old 01-21-2009   #2 (permalink)
PvdG42
Re: Defrag will not work
"Haylesfrend" <Haylesfrend@xxxxxx> wrote in message
news:FEA8F26E-AABE-4EF6-8164-60362EC4F7E7@xxxxxx
> this message:
> if
> Haylesfrend
Probably not in a .NET programming discussion group, but you can find an
appropriate Windows group this way.
As you appear to be using a web interface, start here:
http://www.microsoft.com/communities...s/default.aspx
In the tree on the left, first open the English category, then open Windows.
In Windows, find and open the category for your version of Windows.
There, you'll find a group to post your question.
defrag does not work Vista General
Defrag does not work Vista performance & maintenance
O&O Defrag doesnt work Software
RAID and defrag does not work Vista hardware & devices
Does Vista B2 defrag work? Vista General
