Vista - intermittent workstation trust error calling IsInRole(string)
Old 01-22-2009   #1 (permalink)
asanford
Reposting from microsoft.public.dotnet.security
Can Microsoft please provide some assistance on this item? Thanks!
"asanford" wrote:
Quote:
> We are experiencing intermittent "The trust relationship between this
> workstation and the primary domain failed" (ERROR_TRUSTED_RELATIONSHIP_FAILURE
> 1789) errors in our asp.net web service. We are running Windows 2003 SP2 on
> the load-balanced web machines that are receiving this error, as well as on
> the Active Directory servers. We think the code that is generating the error
> is a PrincipalPermission.Demand() call, which in turn is calling
> WindowsPrincipal.IsInRole(string) to check if an associated WindowsIdentity
> user is a member of the specified group (all groups are domain groups.) The
> WindowsIdentity is constructed by calling Win32’s LogonUser() and then
> constructing a new WindowsIdentity with the resulting access token. The
> account running the IIS app pool is a domain account.
> We’ve looked thru the various windows event logs on both web machines and
> DCs and didn’t see anything obvious, we have run “netdom verify
> [computername]” on all the machines to verify the “secure channel” between
> the given machine and the domain, which succeeded on all machines except one
> of the DCs (we think the FSMO DC (?) – BTW, is this normal for this to fail
> on the FSMO DC?) We have also browsed thru the computer accounts in the AD
> users MMC app, etc – didn’t get any errors there. We also checked the time
> synchronization between all of the servers and that looked correct.
> We haven’t yet taken the steps of, for each web machine, resetting the
> computer account in AD, removing the machine from the domain, and then
> re-joining it, since in general things seem to work.
> Perhaps the problem could be an intermittent network link between web and AD
> machines? Or perhaps there’s a problem during high load? Perhaps a certain
> AD logging level to watch?
> Is there a recommended way to diagnose ERROR_TRUSTED_RELATIONSHIP_FAILURE
> errors, especially intermittent ones?
> Any ideas would be much appreciated.
> Thanks!
Old 01-22-2009   #2 (permalink)
Cor Ligthert[MVP]
Re: intermittent workstation trust error calling IsInRole(string)
Asanford,
As you want using this newsgroup help from Microsoft, you need an MSDN
subscription.
By login on to that using your normal MSDN account you can go to the managed
newsgroups webclient and post your problem using that (I am in doubt if this
is the right newsgroup because this is a developers newsgroup).
Then you will be helped by a Microsoft MSFT in about 48 Hours.
These newsgroups are usenet newsgroups, and as soon as a newsgroup is in
UseNet confirm the rules of UseNet.
Cor
Error handling when calling external executable PowerShell
calling imapi2 put_MultisessionInterfaces return error Vista General
Problem Calling String(char[] value) constructor PowerShell
Designer Media Ltd
