Vista - Web Client Software Factory error Need Help!
Old 02-02-2009   #1 (permalink)
Ann Chang
I installed WCSF on VS 2008. While try to create a new WCSF project, i got a
pop up message as:
Class not registered.
Looking for object with CLSID: {70BAB4E1-E21D-44D0-95D0-5B6312E494D1}
Anyone know what it is?
I have GAX for 2008, VS 2008 SP1 and GAT for 2008 installed.
Thanks!
Old 02-04-2009   #2 (permalink)
Ann Chang
RE: Web Client Software Factory error Need Help!
OK. I figured it out.
Here is the whole process:
I installed GAX for 2008, GAXP1409, GAT for 2008, Enterprise library 3.1,
and WCSF 2008. When i tried to create a new web client solution then i got
the Class not Registered message.
So I removed GAX (1.4.0.9) and reinstall GAX (1.4.0.0), and repaired WCSF
2008, and it works now.
"Ann Chang" wrote:
Quote:
> Hi,
> pop up message as:
> Thanks!
Retrieving the COM class factory... error 80040154. .NET General
vs2008 and web service software factory .NET General
Joyfax Server - Client/server-based fax software allows you to sendand receive fax anywhere Vista print fax & scan
Script error hangs Vista Mail client ads error Vista mail
Error 766 setting up VPN connection client Vista networking & sharing
