| | Create Project.resources.dll like Visual Studio Hi I have been working on this for days and feel there may not be an easy answer. I have a very large solution with 171 projects. some projects have over 60 forms or web pages. I have spent some time creating a tool that extracts all .resx files. Creates a dummy translation then saving a culture version of this file (e.g. form1.<culture>.resx. I have then created a \<culture>\MyProject.resources.dll using resgen.exe and al.exe. The problem I am having is this file is not automatically loaded when the application runs. I would like to be able to create the resources.dll file in the same mannor as Visual Studio does to ensure it is loaded automatically when a culture is set. The reason I don't want to manually load this sat assembly is because there are litterally 100's of forms and web pages in the solution and it would be too time consuming. Is there a way I can create my .resource.dll file in the same way as VS so it is automatically loaded? Thanks in advance. Steven. |
| Empty Project in Visual Studio 2008 | .NET General | |||
| Visual Studio 2008 Link Error for VS6.0 Project | .NET General | |||
| PowerShell Visual Studio project template wiped out all other templates | PowerShell | |||
| Visual Studio Shuts Down Unexpectedly When Loading Project - ASP.NET Web Application running against IIS | .NET General | |||
| Tool To Create Function Map Of C#.NET Project In Visual Studio 200 | .NET General | |||
