| | Can't read appSettings of IE hosted control when under SSL I have the following issue. ..NET Windows Forms control hosted in the Internet Explorer cannot read application settings from the configuration file when page is accessed over SSL (https://localhost/default.aspx). Works fine when accessed using "http://". In both cases control itself loads and works fine. Here are related code fragments: ---cut---file:default.aspx--- ...... <!-- Configuration --> <link rel="configuration" href="MyControl.DLL.CONFIG"> ...... <object id="MyControl" classid="https://localhost/MyControl.DLL#MyControl"> ...... ---cut---file:MyControl.cs--- // Doesn't matter if ConfigurationManager.AppSettings are used instead. string[] allKeys = ConfigurationSettings.AppSettings.AllKeys; ---cut---file:MyControl.DLL.CONFIG--- <configuration> <appSettings> <add key="MyKey" value="MyValue"/> </appSettings> </configuration> ---cut--- allKeys returns empty if page is accessed using "https://", otherwise keys are in place as expected. Environment: Windows XP SP2, .NET 2.0, Internet Explorer 6.0, IIS 5.1, Self-signed SSL certificate, VS2005 |
| Setting properties on hosted toolstrip control at design time | .NET General | |||
| Security questions around browser hosted control interaction. | .NET General | |||
| appSettings at Web.Config | .NET General | |||
| Re: Problem running .NET user control hosted on Windows Vista / IE 7 | Vista security | |||
