| | System.Deployment.Application.InPlaceHostingManager.AssertApplicat I'm using the class InPlaceHostingManager to programmatically run clickonce applications. The following code works fine on Vista if I call the AssertApplicationRequirements with a parameter of true. Without passing true to the AssertApplicationRequirements method I get the error "User has refused to grant required permissions to the application". On XP (with System.Deployment.dll version:2.0.50727.1433) the method AssertApplicationRequirements does not allow me to pass any parameters and I get the same error "User has refused to grant required permissions to the application". Is there a way to get this to work in XP? How do I get the System.Deployment.dll with the new method installed on XP? ApplicationTrust trust = new ApplicationTrust(); PermissionSet set = new PermissionSet(PermissionState.Unrestricted); PolicyStatement ps = new PolicyStatement(set); trust.DefaultGrantSet = ps; trust.ApplicationIdentity = e.ApplicationIdentity; trust.IsApplicationTrustedToRun = true; ApplicationSecurityManager.UserApplicationTrusts.Add(trust); iphm.AssertApplicationRequirements(true); ---- (true) not supported on XP |
| Help: "i Windows Defender: A System Change Was Made by a Known Application" After System Start? | Vista General | |||
| Help with Deployment Workbench and Deployment Services | Vista installation & setup | |||
| VB.NET application cliick-once deployment via internet - Error - Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. | .NET General | |||
| Micrsoft Deployment and Vista image deployment.... | Vista installation & setup | |||
