Vista - help with defender
Old 03-09-2009   #1 (permalink)
karenrd
help with defender
Hi, I'm after some help with windows defender. When I turn on my computer I
receive this error message ' windows defender failed to intialize,
0x800106ba' I receive this everytime I turn on my computer and when I try to
open up windows defender. I can't uninstall it as I doesn't sure up on the
'add/remove programs'.
I have vista on my laptop!
Please help!
karenrd
Old 03-09-2009   #2 (permalink)
Mahmoud Ghoz |
Re: help with defender
Hello karenrd,
I guess you should redirect this question to Vista forum. I am not sure what
is your problem is but when i google about it, i found solution.
http://blogs.chron.com/techblog/arch...tialize_1.html
http://answers.yahoo.com/question/in...1111413AAwahSU
These two posts sure will solve the problem for you.
Mahmoud Ghoz
www.Ghoz.NET
> computer I receive this error message ' windows defender failed to
> intialize, 0x800106ba' I receive this everytime I turn on my computer
> and when I try to open up windows defender. I can't uninstall it as I
> doesn't sure up on the 'add/remove programs'.
> Please help! karenrd
Old 03-10-2009   #3 (permalink)
karenrd
thanks Mahmoud Ghoz l, I tried the 'solutions' with no luck, they are
suggesting I uninstall defender on 'add/remove programs' but I can't do this
as defender isn't listed as a program to add/remove. Any other suggestions?!!
I will try to direct this question to Vista forum and see if anyone has any
bright ideas!!!
karenrd
"Mahmoud Ghoz |" wrote:
Quote:
> Hello karenrd,
> Mahmoud Ghoz
> www.Ghoz.NET
Old 05-08-2009   #4 (permalink)
800106ba
RE: help with defender
> Please help!
> karenrd
Defender Vista security
win. Defender Vista General
defender Vista hardware & devices
Defender Vista installation & setup
Error in Windows Vista Defender cant change anything in Defender! Vista security
