| | Resolution Overlap Problem I created an app and run it on my computer... it all looks great. Installed it on a computer with a different resolution and some of the labels and text boxes overlap with eachother. I used the default font for these - Microsoft Sans Serif, 8.25pt ( both text box and label use these ). What do I have to do so the text box and the label does not overlap in different resolutions? Thanks, Miro |
| | Re: Resolution Overlap Problem > What do I have to do so the text box and the label does not overlap in Quote: > different resolutions? http://www.eggheadcafe.com/conversat...eadid=30192376 Dawid Rutyna |
| | Re: Resolution Overlap Problem I tried the AutoScale, DPI didnt work, setting it to "None" worked better, and still had some minor overlapping. I have tried this as well: ( it did not work either ) Dim fNewForm As New frmMyForm 'This setting did not work either fNewForm .PerformAutoScale() fNewForm .MdiParent = Me fNewForm .Show() Just wondering if anyone else has run into this situation and what their solution is. I didnt even realize this setting existed in windows. For the most part, the rest of the form looks fine. Mir "Dawid Rutyna" <rutynad@xxxxxx> wrote in message news:gpb1la$pvr$1@xxxxxx Quote: Quote: >> What do I have to do so the text box and the label does not overlap in >> different resolutions? > Try this: > http://www.eggheadcafe.com/conversat...eadid=30192376 > > Dawid Rutyna > |
| Files Overlap in Folder? | Vista file management | |||
| Resolution problem | Vista performance & maintenance | |||
| F# and Powershell Overlap | PowerShell | |||
| Lines of text overlap | Vista General | |||
| Name resolution problem | Vista networking & sharing | |||
