Vista - Custom Control issue in design view
Old 03-16-2009   #1 (permalink)
Tom P.
I am trying to make a custom control. The problem I'm having is that
if I inherit from Control I can't get the bloody thing to display
anything. But if I inherit from UserControl I can't hide any of the
properties (namely the size). How do I get the control to display in
design view and still retain control over the properties?
Thanks in advance,
Tom P.
Old 03-16-2009   #2 (permalink)
Dawid Rutyna
Re: Custom Control issue in design view
You will find solution for both cases (showing, hiding) here:
http://www.c-sharpcorner.com/UploadF...blePicBox.aspx
Dawid Rutyna
Old 03-16-2009   #3 (permalink)
Dawid Rutyna
> anything.
"the Control class defines the bounds of a control (its position and size),
although it does not implement painting."
So you have to do it yourself, nice example:
http://www.codeproject.com/KB/tabs/flattabcontrol.aspx
Dawid Rutyna
Old 03-16-2009   #4 (permalink)
Dawid Rutyna
Maybe at the beginning try to paint this:
http://en.csharp-online.net/Architec...Custom_Control
Dawid Rutyna
Old 03-17-2009   #5 (permalink)
Tom P.
> Thanks in advance,
> Tom P.
OK, I figured out the issue. The Control object doesn't display itself
in the IDE unless you place it in a control or form. I guess this is
so it doesn't have to execute any paint code or other stuff that might
blow-up at design time.
If you want to see a control inherited from Control, place it in a
Form.
Tom P.
Control panel view issue Vista performance & maintenance
