Vista - Project References.
Old 03-23-2009   #1 (permalink)
Adrian
Project References.
We've come across a problem using source control when dealing with project
references and are looking to find out what the proper way of dealing with
this is.
When we add a reference to an assembly (in this case to
ajaxcontroltoolkit.dll), it seems to put the full path to the dll in the
project reference. Unfortunately as this is under the program files area,
it causes problems because some developers don't have a program files area,
they have a program files (x86) area instead, so the project doesn't find
the assembly when they download the project it from source control.
How should this be done to avoid this kind of problem?
TIA.
Adrian
Project properties -> References error .NET General
VB Commandline compiler references .NET General
In any project, Can't we refer classes directly, (without addingphysically in the project)? .NET General
Microsoft Advances Its Project Management Technology and the Project Management Profession Vista News
