| | executing scripts within a web browser control under the system ac We have a .Net 2.0 webservice hosted under IIS that converts classic ASP webpages into image files. When run under the system account, the underlying web browser control is failing to execute the script that populates the page with its data (the resulting image contains the static HTML elements, but no data). Running a command line app, which bypasses webservice wrapper and calls the conversion code directly, works as expected producing the static HTML with the dynamic data. However, if the command line app is scheduled to run using the "at.exe" command under the system account, the conversion exhibits the same behavior as the webservice, that is, the dynamic data is missing from the form. This points to a security restriction with executing scripts within a web browser control under the system account. How do we remove this restriction (group policy setting, internet setting, etc)? |
| Executing PowerShell Scripts with IIS | PowerShell | |||
| executing powershell scripts on server | PowerShell | |||
| Executing batch files in PS scripts | PowerShell | |||
| executing scripts async on remote hosts | PowerShell | |||
| Executing scripts in the current directory | PowerShell | |||
